Old 09-23-2006, 05:00 PM   #41
topcop38
Member ID: 55314
Re: Mpg?
i will be running stock tires and rims. i'm not into the fancy stuff. i'm too old for that now.
i might consider an aftermarket exhaust if it will improve mileage but only for that reason.
another question. will the 2500 fit into a 7' garage door?
my 1500 fits with about 8" to spare.
my door is 83" counting the weatherstrip.
Old 09-23-2006, 06:44 PM   #42
Zick
Member ID: 15311
Re: Mpg?
I don't know, I'm in the same delema as you. My 1500 just barely fits into my garage as it is, and the 2500 seem to sit a little higher so I'm not sure if it will make it or not?
Born on 11/20/06: '07 Classic GMC 2500HD DuraMax Edge Evo
SOLD-03' Silverado ECSB 6.0 LQ9, Patriot LS6 heads, TR230, 31lb inj, TB stall, vette servo, Corsa, HP Tuners
SOLD-99' Silverado ECSB 5.3
Old 09-23-2006, 10:47 PM   #43
topcop38
Member ID: 55314
Re: Mpg?
maybe i'll drop by the dealer tomorrow and measure theirs. if it don't fit then that will help narrow my choices.
Old 12-21-2006, 11:36 PM   #44
Farm Boy
Member ID: 60080
Re: Mpg?
Hey guys, my neighbors got an '06 Dmax K2500HD and pullin a 20000 lb trailer he's gettin about 8-10 mpg. This seems kinda low. Hes also had a lot of trouble with injectors too. Three sets in 50000 miles, all under warranty. Hes really starting to hate this truck. I wanted to know if installing bigger exhaust and a different intake would help his mileage? If so how much? and what is causing his injectors to go bad?
Old 12-22-2006, 09:57 AM   #45
cl1986
cl1986's Avatar
Member ID: 20115
Re: Mpg?
20,000 lbs??? I think 8-10 would be awesome pulling that weight....
If you mean 2000 then thats different.....
The injectors must be a fluke cause the 01-03 had the injector problems....id say he should be able to get a new truck after 3 sets.....has to be the engine....
Is he running any programmers....that may cause the injector problems....
2003 2500hd duramax 4 door with centurion package
Old 12-23-2006, 01:21 AM   #46
Farm Boy
Member ID: 60080
Re: Mpg?
the truck is currently stock, I thought about putting bigger exhaust on it and an aftermarket intake setup. that should help his mileage i would think. I thought maybe too much backpressure would screw up his injectors, just a thought.
Old 12-23-2006, 01:50 PM   #47
cl1986
cl1986's Avatar
Member ID: 20115
Re: Mpg?
this site has excellent answers to your questions....there aint much here on FSC
http://www.dieselplace.com/forum/index.php?
Old 02-07-2008, 10:28 PM   #48
1990gmc305
Member ID: 80758
Re: Mpg?
[quote=chrisk1500]
You are reading 'S' equipped numbers....not 'F' equipped....bump those numbers up a shade.....
What is the diffence between S equipped numbers and F equipped numbers. and how would i tell what a truck is equiqqed with.
