08-02-2006, 07:08 PM
#41
Re: I want my truck to do this!!
Originally Posted by Fast305
You are missing the point, I know the fire is already burning, but the extra fuel will still slow down the fire! I don't care what engine or fuel it is, if you don't have the oxygen necessary to combust the fuel, it is EXCESS FUEL and therefore cools the combustion chamber. EGT vs. Fuel Ratio is an Upsided down U shape. Too much or Too little will lower EGTs, as you hit stoichiometric (14.3:1 for diesel) EGTs will rise.
I can gurantee that you will make more power slightly richer than stoichiometric on a diesel, but the tradeoff is you will be changing pistons and valves soon. Peak EGT is actually very close to where your engine is running best. I typically go to peak EGT, then go richer to drop the EGTs down to a safer level.
 Whatever, peak EGTs on a diesel is when your motor melts down.
08-14-2006, 07:42 PM
#42
NO it doesn't. Think of trying to start a fire. When you put on too much wood it just kinda smolders then gets going. OVERICH fuel mixtures do the same thing. Overich mixtures will cool the combustion chamber and EGTs. I hook up EGT sensors on engines that I am tuning for this very reason. I don't care if the engine is gas, diesel, propane, E85, or whatever, when you richen the mixture past what is necessary, it provides a cooling effect.
I disagree...
05 silverado crew cab short bed LT. fast.
Dmax/Ally
(not the same motor it came with from the factory)
08-14-2006, 07:57 PM
#43
Originally Posted by duratothemax
I disagree...
Glade to see I have some backup, but I don't know how you have time to be over here didn't we tell you to get a gf?
08-22-2006, 10:35 PM
#44
Ill back you up! Im assuming that dozer and duratothemax are the same guys over at "the place". Glad to see a few people that know whats goin on.
2002 Chevy CCSB Duramax Diesel
6" procomp, Pillar Guages, 10" sub w/ components,
20" Black KMC Rockstars, 305 Nitto Terra Grapplers
Quad 215/Edge Hot Juice-Att, 4" Exhaust,
08-23-2006, 08:48 AM
#45
x2
07.5 LMM DMAX 2500 HD, ext cab, 4x4
08-26-2006, 06:57 PM
#46
Imagine what it could do if it actually used all the fuel it is dumping in it!
6.0 Vortex Max. 345HP 380lbs torque LT3 pkg 4x4 Black ext cab. Had to sell due to position eliminated by my former f*%$#$@ employer. Hope to buy another one soon but will go with a quad cab this time. Maybe an Avalance if they offer the Max package.
08-26-2006, 07:57 PM
#47
bout to be bodied on 24's
Originally Posted by chrisk1500
x2
most diesel blocks are aluminum and the melts are 1350 F
'06 ECSB: 40 series flowmaster, bagged, false floor bed
'07 CCSB 2500HD: 5" MRBP exhaust, and a BDS 6" lift with 18" XD Series diesel wheels and 35x12.50 nitto mudgrapplers
AFTERMATH-TEXAS
08-26-2006, 09:35 PM
#48
BLOCKS? Are you sure? Every Diesel I have seen has a cast Iron block. Now, that's not saying they aren't out there, but MOST? I don't think so.
Bill
'95 2500 6.5L 5 spd Suburban'07 Kawasaki Mean Streak
08-26-2006, 10:47 PM
#49
Success = Change
Bill
I'll second that
1997 Chevy C1500 Project Truck - Click Sig For Build-Up Thread
08-26-2006, 11:02 PM
#50
my aluminum heads have seen more than 1350 and dont melt down. :)
Dmax/Ally
08-27-2006, 11:18 AM
#51
well in order to melt at 1350 they would have to stay at that heat for an extended period of time and i doubt that you could keep it over 1350 for long enough to melt em
AFTERMATH-TEXAS
08-27-2006, 11:50 AM
#52
oh ive had it over 1350, trust me.
Dmax/Ally
08-27-2006, 09:29 PM
#53
Hog Wild!
Originally Posted by TwoTone98Z71
that vid is old
old, ancient, or new...that vid is fookin kick azz!!
'97 6.5TD 2500HD Ext.CabLB 4L80tranny w/4.10 14B FF,3"pipes,K&N intake,16x8 Eagle Alloys,305/75 BFG AT's
'84 SCSB SB350,Cam,Headers,Edelbrock IM/4barrel,beefedTH350/NP208TC,D60 Front/Detroit TruTrac,14BoltFF w/ Detroit Locker,4.56's,Rancho 6"/3"BL,dual straight pipes,ProComp 15x12,38/15.50 TSLs
08-27-2006, 10:15 PM
#54
Not as much if he then added the fuel to make is smoke again over fueling=more power in the diesel world. It’s nothing to keep EGTs above 1350* and you don't have to worry about the aluminum heads when most diesels have aluminum pistons.
| Thread Tools |
| Display Modes |
Linear Mode
