#1 |
Member ID: 44096
6.5
Hey guys I was wondering were the 6.5TD's the same bellhousing bolt patterns and motor mounts as the 350 in 96. I was thinking of doing a swap into my RCSB for some gas mileage and to be different.
96 RCSB 5.0 Vortec with Vortech charger 6 psi,flowmaster 40 series 2/4 drop, Impala ss wheels
#2 |
Member ID: 26321
Re: 6.5
The bellhousing is the same, but I'm not sure on the motermounts.
Bill
'99 2500 Suburban'07 Kawasaki Mean Streak'97 Chevy XCSB 4X4 350 Vortec 1500 '94 GMC Crew Cab 4X4 Diesel 3500
#3 | |
Keep on truckin
Member ID: 28536
Re: 6.5
Thats a really good idea,Ive thought of it several times.....There was one in town here 94 RCSB 4x4 6.5 dunno if its still around tho,but the dealer sells the motor mounts u need for about 50 each,then like Bill said about the bellhousing,hes the diesel KING!!!Right Bill??? ![]() ![]()
#4 |
Member ID: 44096
Re: 6.5
I thought it was a pretty sweet idea espically if you got some Marine injectors and performance stuff like that.
#5 |
Member ID: 46297
Re: 6.5
i'm guessing yall are talkin about the manual and the 4l80e trannies, but would the 6.5 bolt up to the 4l60e? and what upgrades would need to be done to make it survive light duty?
#6 |
Member ID: 26321
Re: 6.5
Thanks Adam. ;)
The 6.5 will bolt up to ALL the GM trannys. The problem with the 4L60 and 4L80 is controlling them. The early 6.5's had a stand alone trans. controller. Later years don't. You can buy a stand alone from a company like JET, or you could buy a book by a guy named Bobbie Martin that explains how to adapt an old GM standalone unit to your truck.The easiest way to do this swap is with a manual Injection Pump off an early 6.5, or even a 6.2. and a manual trans. If going with a manual IP, look for a 4911. These will offer the most performance unless you want to go to a Peninsular marine pump.To be honest though, if I was going to swap a diesel into a gas truck, I'd do a Cummins swap! I love GM diesels, but the Cummins is just SO much better! You could just swap the entire Dodge drivetrain and adapt the speedo somehow... HTH, Bill
#7 |
Member ID: 46297
Re: 6.5
i know the cummins would be best, but its so cheap and easy to find 6.2's and 6.5's that are running fine, wheras the cummins is harder to locate usually and costs more to swap in, usually.
#8 |
Member ID: 46297
Re: 6.5
what model years have stand alone tranny computers? my suburban is a 94 with a 350 tbi, is it a stand alone or was it only 93's?
#9 |
Member ID: 26321
Re: 6.5
Only the Diesels with mechanical injection and 4L80's came with the stand alone computer. The trucks went with a full computer around '92, but full size vans with the 6.5 had them a little longer IIRC.
Oh, FYI, some 1/2 ton trucks came with the 6.5 and a 4L60! Bill
#10 |
Re: 6.5
Last year for a fully mechanical truck was '93. In 1994 they went electronic.
#11 | |
Keep on truckin
Member ID: 28536
Re: 6.5
Like Matts old 95.....No cat converters either ![]()
#12 |
Member ID: 26321
Re: 6.5
Yea, just like that. Did you hear it with the straight pipe?
Hey, you need to change your sig. You have 1 half finished GM truck in the yard! ![]() Bill
#13 | |
Keep on truckin
Member ID: 28536
Re: 6.5
One half finished,only 3 half started ones now ![]() ![]()
#14 |
Re: 6.5
The 6.5's that came with a 60E were non-turbo.....
1/4 Mile ET
16.722 @ 80.701 MPH |
| Advertisements |
| Thread Tools | |
| Display Modes | |
