#21 | |
All That Is Man
Re: how much boost
That may be true of the LB7's, but there you can get that truck moving without really exceeding that - some of the boost increasers on those caused problems because they were mechanical components that bled off some pressure to fool the wastegate. The VVT's controller is electronic & just modifies control over the vanes - like anything else if you run it at the limit all the time, it won't hold up. If you use the extra boost capability sparingly it should be okay
#22 |
Member ID: 25211
Re: how much boost
No it won't, there is one guy who has killed a 05&06 turbo at only 35PSI.
![]() These views expressed on this post are not my own, but rather randomly generated computer gibberish and in no way should be used to judge the author's IQ or mental health. Last edited by dozerboy : 07-28-2006 at 07:06 PM. |
#23 |
Member ID: 51509
Re: how much boost
anyone from cali that has upped there boost? can u tell me how u did it or what shop u went to for it. my friend has 240xs and he can turn up the boost and turn it down. im not looking to hit 600hp just a little more power.
this truck is a everyday driver and i drive a lot. so far iv had my truck for 1 month and have 3k miles. |
#24 | |
All That Is Man
Re: how much boost
One guy is now representative of all Duramax owners? To reiterate, any given component's longevity is relative to the conditions it is subjected to on a regular basis as well as to the driver creating those conditions, regardless of whether it's stock or modified.
#25 |
Member ID: 25211
Re: how much boost
No your right one guy means nothing. So prove your point, show me one Dmax that consistently runs 35psi or over that has lasted for at least 1 year. One thing you’re forgetting about or in all actuality probably know nothing about is turbo efficiency. The stocker is out of its efficiency range over 30-32PSI and the motor will actually make less power when running above that range. And show me this boost controller that ups it to 40PSI, because the only tuner that modifies boost IIRC is the Predator V2.02 and ATS doesn’t sell it.
![]() These views expressed on this post are not my own, but rather randomly generated computer gibberish and in no way should be used to judge the author's IQ or mental health. Last edited by dozerboy : 07-31-2006 at 08:39 PM. |
#26 |
Member ID: 25211
Re: how much boost
Well I owned myself, I found a truck that did run daily and many 1/4 mile passes at over 35PSI until the owner wised up and cut the boost back, but 30-32PSI is still optimum. I still stand by the fact that if you run your stocker over 32PSI your asking for it.
![]() These views expressed on this post are not my own, but rather randomly generated computer gibberish and in no way should be used to judge the author's IQ or mental health. |
#27 | |
All That Is Man
Re: how much boost
for me! I kid - in all honesty if you look through all my posts I wasn't disputing that it isn't his best bet to increase performance, I was just answering Kast's question at face value without getting into it any deeper - he wanted to know if it was possible to turn up the stock turbo's output, and all I was doing was showing him something that would & telling him what boost it'd allow. Outside of that we're pretty much in agreement on the fact that the harder you push it the shorter its life is going to be. In reality if he's looking for better performance, he should start with the basics: electronics, intake, exhaust, and strengthening the transmission. If he wants to go beyond that & really crank up fueling, a good aftermarket performance turbo's a safer bet that'll give better performance when matched to his truck's output than turning up the stocker in any case. Glad we're able to get things back to a civil level!
#28 |
Member ID: 25211
Re: how much boost
Civil??? **** you you ****ing jackass!!!!
![]() ![]() These views expressed on this post are not my own, but rather randomly generated computer gibberish and in no way should be used to judge the author's IQ or mental health. |
#29 | |
All That Is Man
Re: how much boost
#30 | |
Re: how much boost
holy crap who did that!?! ![]() '05 Silver-a-doo LT, CC/SB
Dmax/Ally BIG spinny thing breathing thru two MBRP pipes, lots 'o fuel, and an unblowupable trans. Inside: Some Denali stuff, spaceship dials and guages, "missle launch" switch for the unsuspecting ricer |
#31 |
Member ID: 25211
Re: how much boost
I have no idea, but I also heard he tried to see how high his tranny would bounce out of the back of a Tahoe.
![]() These views expressed on this post are not my own, but rather randomly generated computer gibberish and in no way should be used to judge the author's IQ or mental health. Last edited by dozerboy : 08-14-2006 at 07:01 PM. |
#32 | |
Re: how much boost
LOL what an idiot! '05 Silver-a-doo LT, CC/SB
#33 |
Re: how much boost
I got the edge juice chip on my 03 and my boost never goes over 21....most of the time it reads 19 on WOT....]
Ive also noticed that if you really stomp on the gas it wont let the tranny shift......about 1/2 to 3/4 way to floor is quickest 0-60 time for me.... Or is this my tired tranny at 100k miles?? What do you do to get over 21 psi?? Last edited by cl1986 : 09-04-2006 at 09:34 PM. |
#34 | |
Chest Poundin' Apes!
Member ID: 349
Re: how much boost
2004.5 Chevy CCSB D/A LLY
#35 | |
Member ID: 25211
Re: how much boost
If it won't shift under heavy throttle you’re slipping the tranny. And the edge gets it reading for the stock sensor and it's not very trust worthy. ![]() These views expressed on this post are not my own, but rather randomly generated computer gibberish and in no way should be used to judge the author's IQ or mental health. |
| Advertisements |
| Thread Tools | |
| Display Modes | |
