Old 07-18-2006, 08:45 PM   #1
kast
Member ID: 51509
how much boost
well i just picked up an 06 crew cab longbed 4x4 lt2 now i would like to know if i can get more power out of the stock turbo or what kind of upgrades i can do.
Old 07-18-2006, 09:19 PM   #2
dozerboy
dozerboy's Avatar
Member ID: 25211
Re: how much boost
30-32psi tops, how much power do your want? And why drag race, truck pulls, towing? Your first mod needs to be your tranny.
Old 07-18-2006, 09:52 PM   #3
kast
Member ID: 51509
Re: how much boost
what would u say that i should do to my tranny. im not looking to drag race just seeing what kind of power i could get out of the stock motor. how many pounds of boost does the stock turbo have.
Old 07-18-2006, 10:16 PM   #4
section9z71
took my chevy 2 the levee
section9z71's Avatar
Member ID: 32117
Re: how much boost
dont go too big on the stock motor. head gaskets go.
as for tranny, go with a BD torque convertor. valve body. then for more power, possibly look into the BD intimidator. try mbrp 4" exhaust too
91' SCSBSS 5.7. 5spd. 3.42s. 33-12.5. 3"BL. flowtech headers. bullet. 3". some other things..
Old 07-19-2006, 05:06 PM   #5
STLCHEVYHD
You serious Clark?
STLCHEVYHD's Avatar
Member ID: 13996
Re: how much boost
I've read a lot where the stock LB7 will hold up to 500hp on the turbo, injectors, etc before it can't go no more. So, I'd imagine the LBZ would do the same. But like they said, the tranny will need modifications to withstand the power increase.
-Jason
01 CHEVY CC 2500HD D-MAX 4x4 BLK
4" Magnaflow exhaust
Cooper ST's 285-75-16
BullyDog Triple Dog w/ Outlook, AEM intake
A Very Long Wishlist
Old 07-19-2006, 06:27 PM   #6
dozerboy
dozerboy's Avatar
Member ID: 25211
Re: how much boost
If you really want some power and are willing to add drugs or mod the block get the best tranny out there Suncoast stage 5 or the ATS stage extreme 4. It you just want a pretty fast ~500RWHP truck Suncoast stage 3 or comparable. Stock is 22-23psi. Exhaust is a must and stock intake should be replaced if you want to go higher than 500RWHP. Gauges are a must. With drugs (n2o, propane) stock motor has hit 800RWHP. But daily driven fuel only 500RWHP is about it before things start to go, but the LBZ should hold more yet. I suggest if you really want to get into Dmax performance join dieselplace.com and do some reading and searching.
Old 07-20-2006, 01:02 PM   #7
r1_hauler2
Member ID: 13548
Re: how much boost
Do not worry about head gaskets!!! Chevy had a problem when the duramax FIRST came out, that has been fixed for YEARS already. Listen to dozerboy he speaks the truth.
2002 Chevy 2500hd
Duramax/Allison
Juice/Attitue
CST 6-8" Lift
Toyo M/T 37/13.5/17
17" ProComp 6001
Old 07-20-2006, 01:31 PM   #8
section9z71
Member ID: 32117
Re: how much boost
when did the first duramax come out?
Old 07-20-2006, 02:49 PM   #9
r1_hauler2
Member ID: 13548
Re: how much boost
the duramax was released in 2001.
2002 Chevy 2500hd
Duramax/Allison
Juice/Attitue
CST 6-8" Lift
Toyo M/T 37/13.5/17
17" ProComp 6001
Old 07-20-2006, 06:39 PM   #10
dozerboy
dozerboy's Avatar
Member ID: 25211
Re: how much boost
Stay away from BD for tranny mods unless you are going to stay under 400RWHP and head gaskets are still a problem when exceeding 60PSI without head studs.
Old 07-21-2006, 06:47 AM   #11
r1_hauler2
Member ID: 13548
Re: how much boost
LOL well thats a given. However, the most common tuners/chips will not push you to that limit causing that failure.
2002 Chevy 2500hd
Duramax/Allison
Juice/Attitue
CST 6-8" Lift
Toyo M/T 37/13.5/17
17" ProComp 6001
Old 07-22-2006, 05:26 PM   #12
dozerboy
dozerboy's Avatar
Member ID: 25211
Re: how much boost
No tuner will, adding pane can its all about cylinder presser. Hey what can I say he wants power big power needs a big turbo?
Old 07-26-2006, 07:44 AM   #13
r1_hauler2
Member ID: 13548
Re: how much boost
Very true but my truck is begging me for twins
2002 Chevy 2500hd
Duramax/Allison
Juice/Attitue
CST 6-8" Lift
Toyo M/T 37/13.5/17
17" ProComp 6001
Old 07-26-2006, 09:33 AM   #14
LostBoy
All That Is Man
LostBoy's Avatar
Member ID: 21194
Re: how much boost
If only they'd fit under the hood...
Old 07-26-2006, 10:07 AM   #15
LostBoy
All That Is Man
LostBoy's Avatar
Member ID: 21194
Re: how much boost
http://www.atsdiesel.com/ATSWebsite/...Electronic.asp
There's a boost controller on the very top of the product list that'll allow stock turbo to generate 40psi boost. That'd be more than adequate for a stock truck trying to get a bit more.
That being said, keep in mind turbos are not bolt-on horsepower! It has to be matched to your fueling/horsepower output for the best results, so bigger isn't always better.
Old 07-26-2006, 02:15 PM   #16
r1_hauler2
Member ID: 13548
Re: how much boost
They do I know of a few people over on the diesel place that have gone and added twins.
2002 Chevy 2500hd
Duramax/Allison
Juice/Attitue
CST 6-8" Lift
Toyo M/T 37/13.5/17
17" ProComp 6001
Old 07-26-2006, 10:35 PM   #17
dozerboy
dozerboy's Avatar
Member ID: 25211
Re: how much boost
You push a VVT turbo up to 40psi plan on buying a new one. I have heard of 52psi from a stocker now it’s a paper weight anything over 32psi is asking for it. And twins are no problem just need to relocate one of the batteries.
Old 07-27-2006, 03:27 PM   #18
LostBoy
All That Is Man
LostBoy's Avatar
Member ID: 21194
Re: how much boost
I'd bet if you ask they had to do some cutting on the body to make them work - I don't know of any bolt-on kits but I'd be curious to know who is making them if I'm wrong, so please post back with that if you find out...
kast's question was what what the stock turbo can do - that being said, I haven't heard any problems running the boost controller - be thankful we own GM's & not Fords, whose VVT's are dropping like flies, even on unmodified trucks
Old 07-27-2006, 09:51 PM   #19
dozerboy
dozerboy's Avatar
Member ID: 25211
Re: how much boost
There is o cutting of the body you only need to relocate the battery. There are 2 companies making them they are in-house mods not bolt-ons. And like I said push a stocker over 32psi it won't live.
Old 07-28-2006, 07:17 AM   #20
r1_hauler2
Member ID: 13548
Re: how much boost
Idaho CTD is a company that makes twins for the duramax however they do not have a webpage. I have heard banks was making one but hasn't released it to the public yet. And finally try here www.dieseltrans.com
2002 Chevy 2500hd
Duramax/Allison
Juice/Attitue
CST 6-8" Lift
Toyo M/T 37/13.5/17
17" ProComp 6001
