Old 07-23-2006, 07:12 PM   #1
K5Fury
K5Fury's Avatar
Member ID: 42906
Injectors
I have a '93 with a 6.5td. How often should the injectors be changed? No problems with them just thinking routine maitance.
Old 07-24-2006, 12:57 PM   #2
SuperChevy
Member ID: 9735
Re: Injectors
If you're not having any problems (power drop or mileage drop) theres really no point in changing them unless you're upgrading to better injectors for more power.
Old 07-24-2006, 02:00 PM   #3
red suburban
red suburban's Avatar
Member ID: 46297
Re: Injectors
i've heard some people say to change them at 50k, others at 100k, but only because of power loss. i'd say that if you havent lost any power or gas mileage i wouldnt worry about it. just run some fuel system cleaner through your engine, that would be all i would do for routine maintainance when it comes to injectors.
Old 08-08-2006, 05:27 PM   #4
LostBoy
All That Is Man
LostBoy's Avatar
Member ID: 21194
Re: Injectors
Originally Posted by red suburban
...i'd say that if you havent lost any power or gas mileage i wouldnt worry about it...
Sorry - I may have some OCD at work here, but I've noticed this on several of your posts - Diesels get 0 GAS mileage. You're talking about FUEL mileage/economy. Again - OCD on my part, I had to say something
Now as to the question - injectors aren't like brake pads & designed to wear out (they do eventually, but what doesn't?) They may require service at regular intervals (fuel system cleaner or actually going to a shop that offers an injector flush). Saying you need to replace injectors at a certain mileage as preventative maintenance is like saying you have to replace your engine or tranny @ certain intervals.
Old 08-08-2006, 08:39 PM   #5
chrisk1500
chrisk1500's Avatar
Status: Online
Member ID: 28947
Re: Injectors
When these injectors go bad they can cause severe piston damage due to incorrect spray pattern/dripping.....
The general rule of thumb is 100k for a set of injectors....
If you are on a budget at least pull them out every 50k or so and get them tested at your local injection shop to make sure the spray pattern is correct and that they are popping at the correct psi.......
Run Stanadyne Lubricity or PowerService regularly to keep your injectors and IP lubricated and keep the deposits from building up....
1/4 Mile ET
16.722 @ 80.701 MPH
Old 08-17-2006, 05:15 PM   #6
LostBoy
All That Is Man
LostBoy's Avatar
Member ID: 21194
Re: Injectors
Some would say the same for the 4L60E - I just want to make clear that there's a difference between recommended service interval & life expectancy
