Old 08-11-2006, 09:24 PM   #1
KickAss89chev
Registered Woman Pleaser
KickAss89chev's Avatar
Member ID: 43619
who has the biggest deisel engine on this forum?
well its not mine, its my parents, but i'll start
1986 john deere 8650
1981 Monte Carlo, dual pipes,FOR SALE
1985 Monte Carlo. Dual exhuast on a mild built 350. T Tops
Old 08-11-2006, 10:20 PM   #2
mudpuppy
Member ID: 16684
Re: who has the biggest deisel engine on this forum?
farm mechinery... well my dads company has lots of vehicles with diesels. I dunno which one has the biggest engine, probably the D9R, but the Grove GMK7550 has a massive engine too, and allison tranny...
Old 08-11-2006, 10:59 PM   #3
KickAss89chev
Member ID: 43619
sweet
Old 08-13-2006, 12:15 PM   #4
GetMore
Member ID: 28812
I'm going to say that if you are going to claim that your diesel is big(ger) I want stats.
Give us displacement, or if you want to calim the vehicle is bigger give weight and/or dimensions.
The winner will be the person with the ship, I think.
2001 Silverado 2500HD 4x4, 6.0/4L80E
Stock/tow vehicle
Old 08-13-2006, 12:49 PM   #5
KickAss89chev
Member ID: 43619
stats for 8650
Manufactured: 1982 - 1988
Factory: Waterloo, Iowa
Cost: (US Dollars) $95,000 (1988)
Power:
Engine (HP): 290
Drawbar (HP): 220
PTO (HP): 239
Engine:
Manufacturer: John Deere
Fuel: diesel - turbo
Cylinders: 6
Displacement (ci): 619
Compression:
Rated RPMs:
Torque (ft-lbs):
Firing order:
Oil capacity (qts):
Transmission:
Type: QuadShift
Forward: 16
Reverse: 6
MFWD: 4WD
Capacity:
Fuel (Gal): 214
Cooling (Qt): 48
3-Point:
Category: III
Lift (lbs): 9,260
Power Take-off (PTO):
Type: independent
Rear speed (RPM): 1000
Hydraulics:
Type: closed
Capacity (gal):
Total Flow (gpm):
Outlet Flow (gpm): 32
Outlets: 2
Tires:
Ag front: 18.4-38
Ag rear: 18.4-38
Dimensions:
Weight (pounds): 30,000
Wheelbase (inches): 125
Length (inches):
Old 08-13-2006, 04:16 PM   #6
BagginA93chev
BagginA93chev's Avatar
Member ID: 41306
My Dads semi has a detroit desiel with 500 horsepower and over 1000ftlbs of torque.
layin on 22s
98 cherokee 3in lift with 31in ss ltb, 93 gmc siera layed on 22s
thanks to 97Bowtie1106 for the sig
Old 08-13-2006, 05:12 PM   #7
mveale05
Devil On My Shoulder
mveale05's Avatar
Member ID: 45644
Got to drive this beast around at work one day... [Not actual pictures, but same model].
$250,000
The largest tractor in the series, the Challenger MT865 offers the highest horsepower of any production tractor – track or wheel. Powered by a 964-cubic-inch Cat C16 engine, the MT865 is rated at 500 gross engine horsepower.
• 455 horsepower at the drawbar while producing 26,322 kg of force
• 26,322 kg (58,031 lbs) maximum drawbar pull
• 444 pto horsepower at rated engine speed
• 523 pto horsepower at maximum power
• 58.3% pto torque rise
• 9,496 kg (19,500 lbs) maximum 3-point-hitch capacity
You can set my truck on fire, and roll it down a hill, and I still wouldn't trade it for a Coupe DeVille.
Old 08-13-2006, 06:08 PM   #8
96extcab
FSC's resident HR Guru
96extcab's Avatar
Member ID: 23531
Location: August-May Champaign IL/ May-August Danville, IL
We have a 1975 International Transtar 4200. Eagle Package, 36" crawl through bunk. Don't have any pictures, my dad used it over the road for a short period of time and now its waiting on restoration. It has a Cummins VT903, which is a turbocharged 903 cubic inch V8.
Central Illinois meet in Champaign this Summer clicky---> http://www.fullsizechevy.com/forums/...champaign.html
Old 08-14-2006, 12:00 AM   #9
99silveradoguy
Premium Member #58
Supporting Member
99silveradoguy's Avatar
Member ID: 21186
forget the name but one guy on fsc drives one of them huge ass tow trucks made to tow big rigs and stuff. Believe he said it makes around 1750 ft-lbs must be a sweet engine
- 99 Silverado - retired to spare vehicle
Black headlights/turnsignals/taillights- 6K HID Low beams, back on stock rims. current project/DD 99 jeep TJ
Old 08-14-2006, 12:14 AM   #10
96extcab
96extcab's Avatar
Member ID: 23531
TribalVison
Old 08-14-2006, 12:23 AM   #11
Stigo69
bout to be bodied on 24's
Member ID: 45516
used to run one for Jimmy Evans company here in town....
D10T WH DETAILED SPECIFICATIONS
Engine
Engine Model
CatŪ C27 ACERT™
Flywheel Power
580 hp / 433 kW
Gross Power
661 hp / 493 kW
RPM
1800 RPM / 1800 RPM
Number of Cylinders
12
Bore
5.4 in / 137.2 mm
Stroke
6 in / 152.4 mm
Displacement
1647.5 in3 / 27 L
Weights
Operating Weight
144986 lb / 65764 kg
Blades
Blade Type
U
U-Blade Capacity with Trash Rack
63.9 yd3 / 48.9 m3
U-Blade Width
17.26 ft / 5.26 m
Undercarriage
Track Width
24 ft / 610 mm
Track Gauge
100.39 in / 2550 mm
Length of Track on Ground
12.75 ft / 3880 mm
Ground Contact Area
7326 in2 / 4.7 m2
Track Rollers/Side
8
Dimensions
Ground Clearance
24 in / 615 mm
Width Over Trunnions
12.2 ft / 3.72 m
Width without Trunnions (Standard Shoe)
10.3 ft / 3.16 m
Height
14.24 ft / 4340 mm
Height (Stripped Top)
10.56 ft / 3.22 m
Height ROPS/Cab
13.38 ft / 4078 mm
Height ROPS/Canopy
14.24 ft / 4340 mm
Overall Length Basic Tractor
17.5 ft / 5.33 m
Overall Length with Blade
24.61 ft / 7.5 m
Standards
ROPS
SAE J1040 MAY94, ISO 3471:1994
FOPS
SAE J/ISO 3449 APR98 Level II, ISO 3449:1992 Level II
Rippers
Each Additional Shank
1160 lb / 526.2 kg
Service Refill Capacities
Fuel Tank
318 gal / 1204 L
'06 ECSB: 40 series flowmaster, bagged, false floor bed
'07 CCSB 2500HD: 5" MRBP exhaust, and a BDS 6" lift with 18" XD Series diesel wheels and 35x12.50 nitto mudgrapplers
AFTERMATH-TEXAS
Old 08-14-2006, 08:30 AM   #12
mr_goodwrench_0
Member ID: 26321
Pffttt. We have 190 ton (that's how much you can put IN them) Komatsu 730E dump trucks with 2000 Hp Cummins engines at my work. The Komatsu 5500 SuperShovel that fills them has TWIN 1500 Hp Cummins engines.
Bill
'99 2500 Suburban'07 Kawasaki Mean Streak'97 Chevy XCSB 4X4 350 Vortec 1500 '94 GMC Crew Cab 4X4 Diesel 3500
Old 08-14-2006, 10:11 AM   #13
99silveradoguy
Premium Member #58
Supporting Member
Member ID: 21186
Originally Posted by 96extcab
TribalVison
ah ya,
btw heres tribalvisions wrecker specs
It's a 2006 Peterbilt model 378
the engine is a 565 HP Cummins ISX signature series.
565 Hp and 1850 lbs ft torque.
13 speed transmission and fully locking 4.11 rears.
The wheelbase is 308" and has a 14,600 lb front axle and 46,000 lb rear axles.
the wrecker unit is a 40 ton Challenger 6807 Traveler with and SDUIII underlift.
Old 08-14-2006, 10:24 AM   #14
Stigo69
Member ID: 45516
ah ya,
Must pay good with all the money he has in his show truck
AFTERMATH-TEXAS
Old 08-14-2006, 12:06 PM   #15
Bob T
Premium Member #26
Supporting Member
Bob T's Avatar
Member ID: 13228
FAIRBANKS MORSE ENGINES
ENGINE # 1
Model: 38D 8&1/8, 10 Cylinder Marine Reversible
Serial Number: 836198; Date Manufactured: 1944; Re manufactured and updated by Fairbanks in 1964
Horsepower 1,700
RPM 750
Condition: Unused since rebuild and corrosion protected
Shipping Dimensions: Crate 251"L X 75"W X 133"H; Approximate shipping weight with crate: 40,715 lb. Price: $45,000.
Old 08-14-2006, 12:15 PM   #16
KickAss89chev
Member ID: 43619
now i feel like dumbass, lol
Old 08-14-2006, 12:33 PM   #17
1996Silverado
Premium Member #120
Get in sit down hang on.
1996Silverado's Avatar
Member ID: 7737
When I was stationed at Fairchild AFB in WA, we had a choo-choo in the railhead I used occasionally. I think it made 3200 hp. DOn't know the engine specs.
5.7, FIPKII, Elect Fans, S/S Headers, Duals, Wait4Me, 4/5 drop on 18" Weld Evo Velosity's. STOLEN ON 9/9/2006
http://www.fullsizechevy.com/forums/showthread.php?t=229807
Old 08-14-2006, 12:34 PM   #18
Yamsi401
Yamsi401's Avatar
Member ID: 51767
Why do people spend over $100K on a tractor and the barn looks like its about to fall apart?
The garage
'86 Jeep 2.8 V6 (#2 Son's)
'97 Jeep 4.0 I6(#3 Son's)
'05 Jeep 5.7 HEMI (my lovely wife's)
'06 Silverado 2500HD LT3 w/LBZ Diesel 4x4
http://www.cardomain.com/ride/2419360
Old 08-14-2006, 07:27 PM   #19
whitesilvy2000
AKA Slim Picks
whitesilvy2000's Avatar
Member ID: 52450
Emd V16
Old 08-14-2006, 08:07 PM   #20
dozerboy
dozerboy's Avatar
Status: Online
Member ID: 25211
I run equipment that runs up into the 500hp all of the time, but do I win for post The Biggest Diesel Motor in the World?
