#1 |
Member ID: 1081
compression brakes
why don't the big three use compression brakes in their diesels? is it because it is a noise issue? No need for it?
03 chev rcsb 5.3 project
#2 |
Status:
Online
Member ID: 25211
Re: compression brakes
cost??? who knows
![]() These views expressed on this post are not my own, but rather randomly generated computer gibberish and in no way should be used to judge the author's IQ or mental health. |
#3 |
formerly P379XL
Status:
Online
Member ID: 19024
Im no diesel genius, but I doubt the big three have seen enough reason to put 'Jake brakes' in their engines. With aftermarket exhaust brakes, the truck brakes, and electric trailer brakes, I guess they figure the braking side of things is covered.
![]() 1993 Chevrolet C1500 - 1998 Chevrolet S10 - 2008 Honda Rancher |
#4 |
14 MPG BigBlock
Member ID: 39893
Dodge offers one as an option on the Cummins. pricey, but worth if it's loaded a lot
Old Truck:1994 K2500 6 lug. Hooker comps. Gibson catback, Jet stage 2, K&N cold air,TB spacer & 3:73 posi.
New Truck: 2003 2500 HD. Stock, Stock and Stock. not for long edit: totaled 5/6/06. RIP New New Truck: 2004 2500 HD.8.1 Alisson CC. Loaded |
#5 |
Premium Member #5
Original Gold Member
Member ID: 347
GCWR is less than what requires a "jake" brake.
![]() Much like alcohol, tobacco, and voting there should be an age requirement for computer usage. "Drag racing helps me get rid of all my extra cash." Team credit card holder and crew chief - "Hot Rod" Heather JD4193 & Holly "Wood" JD4145 |
#6 | |
Just Bump It
And I'd venture a guess that 50% of the people who own these trucks don't even tow half of that.
#7 |
not cost effective to put on a light duty truck. Its not needed either, especially with the Allison's grade braking and tow-friendly features. Noise restrictions, complications in engine design....many many reasons its just not feasible in a light duty truck. As far as I know Dodge does not offer an engine brake on the Cummins. An exhaust brake MAYBE, but thats not an engine brake.
'05 Silver-a-doo LT, CC/SB
Dmax/Ally BIG spinny thing breathing thru two MBRP pipes, lots 'o fuel, and an unblowupable trans. Inside: Some Denali stuff, spaceship dials and guages, "missle launch" switch for the unsuspecting ricer |
#8 |
Member ID: 1081
Well I guess it's good that they don't offer these in The aftermarket, Cause I am pretty sure guy's would be cruising around using them during the middle of the night.
#9 |
All That Is Man
It isn't always completely pointless, but where you live can even play a lot into the need. Here in Colorado, its not hard to heat service brakes up in a hurry through mountains on steep grades. They're still not strictly necessary even in that situation if you remain within GCWR, but buying an exhaust brake once is a lot cheaper than buying service brakes over and over...
Cummins does offer an exhaust brake on the later models - I think 05+ - made by Jacobs IIRC All in all & like anything else with an OEM it wouldn't be cost-effective for them to do it, especially considering the percentage of people that would actually ever need one or use one if it came with the truck.
#10 |
Member ID: 28812
I think it is mostly cost, but there could be an emissions issue involved.
I don't know what is considered a compression brake. I know there is the "Jake brake", which I think is the compression brake. This releases the exhaust valves at the top of the compression stroke, making the engine a big, noisy air compressor. Noise regulations would keep this from being installed on an average-consumer level vehicle. Exhaust brakes are becoming common on medium duty trucks. They are quiet and still provide braking power. All they are is a butterfly in the exhaust that causes backpressure. I think the other reason that engine retarders aren't placed in light duty trucks is because you have to get used to them. When you let off the throttle they activate, so you can't coast. You need to learn to keep a light foot on the throttle, and not lift too much to keep from activating it. The average person would complain about it and the reduced mileage they get from not being able to coast. Of course you can switch it off, but that just causes it's own list of complaints. Plus, it could possibly lead to a loss of control on slippery surfaces when the truck is unloaded, due to the braking at the rear wheels. For the people that know what they are doing it is a good thing to have, but the Big Three have to look at the idiots that are out there when they decide to do this or not. Leaving it to you and the aftermarket takes the blame off them.
2001 Silverado 2500HD 4x4, 6.0/4L80E
Stock/tow vehicle |
#11 |
All That Is Man
Higher performance = higher maintenance. OEM's have to find a middle ground between performance & durability. If you're going to go to the expense and effort of modifying, you're likely more in-tune w/ your vehicle than the average driver, meaning you'll probably maintain it better. They have to assume most people are totally ignorant when it comes to their vehicles in general, much less how to take care of it, and that they'll likely slack.
| Advertisements |
| Thread Tools | |
| Display Modes | |
