Old 08-15-2006, 12:18 AM   #1
94stepside5.7
4/6 dropped Silvy on 22s
Member ID: 40992
6.5 Diesel
I am about to buy a 95 GMC 2500 diesel from a friend. He told me that the engine was replaced with a 97 6.5, is there any difference between the 95 and 97 6.5s? Also, how much horsepower and torque do these engines have? Thanks for the replies.
Old 08-15-2006, 08:04 AM   #2
mr_goodwrench_0
Member ID: 26321
Re: 6.5 Diesel
Fortunatly for you, the '97 has some cooling upgrades done to it that help when towing heavy loads. This includes a high output water pump and a dual thermostat housing. There is a well known problem with these engines, but it's an easy fix. On the side of the Injection Pump is an electronic device that tends to malfunction over time due to heat. The fix is to buy a new unit (PMD), a wiring extension and a heat sink. Mount the new PMD on the heat sink out of the engine bay and it should offer trouble free operation. Symptoms of a bad PMD include hard starting once the engine is warm, and/or intermitant stalling.
Hp is around 200 IIRC, but I'm not sure about torque.
HTH
Bill
'99 2500 Suburban'07 Kawasaki Mean Streak'97 Chevy XCSB 4X4 350 Vortec 1500 '94 GMC Crew Cab 4X4 Diesel 3500
Old 08-15-2006, 08:39 AM   #3
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Re: 6.5 Diesel
The 97 engine also differs from the 95 in that the 97 has oil spray nozzles to cool the underside of the pistons....the material they took out of the block to fit the nozzles *may* have contributed to a weaker block in 97 and 98 (506)...
1/4 Mile ET
16.722 @ 80.701 MPH
Old 08-15-2006, 09:04 PM   #4
mr_goodwrench_0
Member ID: 26321
Re: 6.5 Diesel
Yea, there is that too.
Bill
Old 08-15-2006, 10:33 PM   #5
94stepside5.7
Member ID: 40992
Re: 6.5 Diesel
Thanks for the replies guys, now I know a little more about this truck. Good to know in case I have that problem.
Old 08-17-2006, 12:31 AM   #6
94stepside5.7
Member ID: 40992
Re: 6.5 Diesel
What would be city and highway mpg for a 6.5 with a 5 speed manual tranny? I know it has to be better than my 5.7, Thanks for the help.
Old 08-17-2006, 05:53 AM   #7
K5Fury
K5Fury's Avatar
Member ID: 42906
Re: 6.5 Diesel
Anywhere from 18-24 mpg.
Old 08-17-2006, 11:43 PM   #8
94stepside5.7
Member ID: 40992
Re: 6.5 Diesel
Thats sounds great, My 5.7 only gets around 12 in the city and 16on the highway.
