Old 09-10-2006, 01:47 PM   #1
Firestrike87
Premium Member #51
Didn't know what to type.
Firestrike87's Avatar
Member ID: 44112
LB7 or LLY
Which Durmax is better? What is the difference between the two?
1997 Z71 | 6" BDS | 35x12.5 M/T Baja Claws | 15X10 Classic II | Flowmaster 40 Series | 5.7 Vortec | 4L60E | 3:73
Check out my Cardomain site for pics - http://www.cardomain.com/ride/1833894
Old 09-10-2006, 02:32 PM   #2
Big Angry
Chest Poundin' Apes!
Big Angry's Avatar
Member ID: 349
Re: LB7 or LLY
It's a preference thing, I am partial to my LLY, the LB7s were plagued with injector issues, some LLY's are overheaters. The LB7's have a 200k warranty on injectors now, mine doesn't. The LLY is from the block up, basically a completely different motor, VVT turbo, instead of a wastegated turbo, the injectors are a lot easier to get to if you ever have to do work to one, different HP and torque ratings, there are more, but those are the main differences.
2004.5 Chevy CCSB D/A LLY
Old 09-10-2006, 03:17 PM   #3
Firestrike87
Premium Member #51
Member ID: 44112
Re: LB7 or LLY
If I am looking for used, is there any way to tell if an LLY was an overheater?
Old 09-10-2006, 04:42 PM   #4
Big Angry
Big Angry's Avatar
Member ID: 349
Re: LB7 or LLY
hook 10,000lbs to it and drag it up a 7% grade for about a mile or so, with the a/c cranked, preferably in warmer weather.
Otherwise, no. What are you buying it for? To hot rod? or to tow big arse loads? If you don't tow a real big load, you may never know, nor may it matter. But there are no tell tale signs.
Old 09-10-2006, 05:56 PM   #5
Firestrike87
Premium Member #51
Member ID: 44112
Re: LB7 or LLY
I am looking at diesels so I can have the power IF I WANT to hot rod it. By no means will I beat on it, I don't beat on anything, but I want to ability to everynow and again. Also, I want to be able to tow a heavy load if it is needed. I would much rather be overkill on power than possibly pushing a 6.0 to its limits. So in that case, I may never know if it will overheat, but then the question arises about the new diesel fuel that is coming out. How will that affect a 2004.5 in 4 or 5 years? or longer?
Old 09-10-2006, 06:07 PM   #6
Big Angry
Big Angry's Avatar
Member ID: 349
Re: LB7 or LLY
By hot rodding it, I don't necesarily mean "Beat it" or abuse it. I don't tow a damn thing with mine, but I like having the power it does. How heavy? How often? I would take my chances with an LLY over the injector issue with the LB7. There is a fix for the LLY, it's just not recognized or paid for by GM. The fuel will be out this year, so the only way to know how it will affect an LLY in 4 or 5 years is check back in 4 or 5 years, my crystal ball isn't working, lol. The fuel is going to have the same affect on all Dmax engines, be it LLY or LB7. If I were going to buy any other engine than a Dmax, it would be Cummins all the way, not a 6leaker from ferd.
Old 09-10-2006, 06:12 PM   #7
Firestrike87
Premium Member #51
Member ID: 44112
Re: LB7 or LLY
By fuel issues, I mean is it going to change how the vehicle runs and operates? Is there going to be power loses, are the vehicle owners going to have to change anything to their specific vehicles to be able to use this new fuel? Or am I just overeacting?
Old 09-10-2006, 06:13 PM   #8
Big Angry
Big Angry's Avatar
Member ID: 349
Re: LB7 or LLY
Over reacting. The point is NO ONE KNOWS. Don't sweat it.
Old 09-11-2006, 12:20 PM   #9
duratothemax
Member ID: 53120
Re: LB7 or LLY
Originally Posted by Big Angry
The LLY is from the block up, basically a completely different motor.
LLY's and LB7's are identical except for the turbo, injectors, ECM, turbo, and heads. All of the internals, rods, pistons, blocks, are identical/interchangable. I wouldnt go so far as to call it a completely different motor....
"some" LLY's overheat because of the variable vane turbo and EGR.
'05 Silver-a-doo LT, CC/SB
Dmax/Ally
Old 09-11-2006, 05:29 PM   #10
Big Angry
Big Angry's Avatar
Member ID: 349
Re: LB7 or LLY
Ok Ben, how's about somewhat significantly changed, is that more accurate?
Old 09-11-2006, 05:43 PM   #11
duratothemax
Member ID: 53120
Re: LB7 or LLY
mehhh...now you're getting technical and splitting hairs!
Dmax/Ally
