#1 |
6.5 potential
My dad just got a bullydog system in his truck and it pretty much got me hooked on diesels.
The local auto traders have basic work trucks for a few grand with a 6.5 Power wise, what could a 6.5 be capable of making? |
#2 |
Re: 6.5 potential
snoop around peninsular diesel to see what kind of potential they have...
1/4 Mile ET
16.722 @ 80.701 MPH |
#3 |
Member ID: 46297
Re: 6.5 potential
check out www.dieselplace.com in the 6.5 section.
the initial problem with making big power with this engine is the compression ratio (around 21:1, for power you need 18:1). all it takes is some 18:1 pistons to fix that. gm8 turbo or a banks kit will help out alot more as well. |
#4 |
Member ID: 28691
Re: 6.5 potential
The thing to remember with a 6.5, is they're basically a modded 6.2 in the first place, going nuts on one with upgrades is a good way to crack a block. With sensible mods ie, exhaust, intake, gauges, and a mild reprogram or chip, with a F engine it isant unreasonable to make 260hp and 475ft'lbs safely.
1998 GMC Sierra SLE K1500 6.5LTD X-cab 8'box HD Chassis L480E with cooler 3.73 14bolt rearend (currently~71K)
3" downpipe back Mandrel Bent exhaust,3" High-flow Walker cat, 3" Dynomax Bullet |
#5 | |
Re: 6.5 potential
You will probably need to go 18:1 to make those numbers.....still easily done.....just takes $$$
1/4 Mile ET
#6 |
Member ID: 46297
Re: 6.5 potential
i think the name of a company called penninsular sells 6.5 crate engines with 300hp. check on dieselplace in the 6.5 section.
| Advertisements |
| Thread Tools | |
| Display Modes | |
