Old 09-12-2006, 12:06 PM   #21
foreman00081
IM MIKE D
foreman00081's Avatar
Member ID: 50102
Re: Does towing hurt D-Max power?
firestrike, if you want to find out about diesels you really should check out dieselplace.com like the other guys mentioned. there is more information then you will ever want to know and tons of guys that are willing to give help and advice on anything from maintinance to towing/hauling and tons of modifying info. FSC is a great site and all but there arent really many of us that have diesels on here so finding info here is much more difficult. my advice would be to definetly get a diesel, you will love it and even with minor mods they can be really fast and still get great milage. and as far as milage goes, 100k is nothing on a diesel truck and towing 5th wheels and stuff like that is what theyre made for so as long as a trucks been maintained properly you shouldnt have any major problems.
Old 09-12-2006, 12:21 PM   #22
Firestrike87
Premium Member #51
Didn't know what to type.
Firestrike87's Avatar
Member ID: 44112
Actually, I have been spending A LOT of time at dieselplace.com web site lately. I have learned so much in the past few days about diesels its nuts. My only problem is on forums, it seems like only people with problems will leave any sort of a message so I don't really have any idea of how large of a problem something really is. I couldn't begin to decide what percentage of LLY's overheat and what percentage of LB7's have injector issues. I just what to know what engine gives me a better chance of a great truck. It doesen't seem there is a solution for an overheater, but GM does warrenty injector's for 7 years, but only on 01 and 02. So it seems the 03's are kinda left out it the dust.
1997 Z71 | 6" BDS | 35x12.5 M/T Baja Claws | 15X10 Classic II | Flowmaster 40 Series | 5.7 Vortec | 4L60E | 3:73
Check out my Cardomain site for pics - http://www.cardomain.com/ride/1833894
Old 09-12-2006, 12:36 PM   #23
LostBoy
All That Is Man
LostBoy's Avatar
Member ID: 21194
Originally Posted by Firestrike87
Thanks for the heads up, but when you say "quite a few miles" what does that mean? Also, how often are you supposed to change the injectors and glow plugs? What is a rough idea for price's on changing them? Is it difficult to change a fuel filter on a diesel? I have never had to replace one so don't know if it is difficult at all.
Try not to get too far ahead of yourself... Injectors aren't scheduled maintenance, you simply replace them if they fail, just like on a gas engine. Oil changes are quite a bit more, but service intervals are farther apart. As for mileage, low to mid 100's on an 01 is pretty low.
Is it true that all the Duramax's between 01 and 03 have injector issues? Is there a solution to that? If I buy a used truck, I won't have a warrenty, and I don't want to pay $1,000 dollars to get an injector replaced because GM had faulty injectors. I realize that 01 and 02 have a 7year warrenty on injectors, but I want an 03 or newer, which doesn't have that same warrenty. Is there even an aftermarket solution to the injector problem? If there is at least a solution, that would completly change my mind on going diesel.
Yes, some of them had injector problems - GM updated the fuel filter and extended the warranty period as a result. In any case, you can get a full set of performance injectors to replace the stockers for $1200 (again, that's a set, not just 1), and they can provide 75+ hp.
Old 09-12-2006, 05:11 PM   #24
CrazyJohnny
Member ID: 34768
i say at 100k you are just breaking in your diesel, just make sure to have the injectors serviced, tranny flushed, and filters cleaned
Old 09-12-2006, 09:44 PM   #25
dozerboy
dozerboy's Avatar
Member ID: 25211
X2 on the 100K, but there is no servicing for injectors, do not flush the tranny, and filters are to be replaced not cleaned.
Firestrike
IMO there is a good bit of misinformation in this thread. I made a post with a few tip on how to avoid bad LB7s/LLYs on here. Doing your own maintenance will save you a lot of $$ and there is nothing to it.
Old 09-12-2006, 10:44 PM   #26
duratothemax
Member ID: 53120
LB7 (2001-2004) injectors have a 200,000 mile warrantee. Dont worry about the injectors. The LB7's are great engines.
'05 Silver-a-doo LT, CC/SB
Dmax/Ally
Old 09-13-2006, 05:11 AM   #27
foreman00081
IM MIKE D
Member ID: 50102
firestrike, i hope i didnt give you the wrong idea, i wasnt meaning dont post over here and i agree with you about people only posting when theres problems but i was pretty much saying the same thing as dozerboy that there is a lot of misinformation in this thread and just by reading it it looks like the dmaxs are nothing but trouble with injectors failing and engines blowing up all the time (which totally isnt true) so to someone with little experience with diesels (which im in the same boat as you, ive only had mine for about 6 months so im still learning too) it might scare them away. so all in all i was just trying to make sure you saw more information then what was on here before you made your decision. ok, sorry about the long post and i hope some of that made sense. and again, get the DMAX, blow some smoke, and have fun blowing the doors off some ricers, trust me youll be soo glad you did.
Old 09-13-2006, 07:08 AM   #28
Firestrike87
Premium Member #51
Member ID: 44112
I will keep posting over here for sure. By no means did you give me the wrong idea about diesels on this site, I just want to make sure I get the correct information. Something that I did find on the dieselplace.com site was that they have a place where you give them a vin number and they can give a complete list of info about that truck since day one. I will be able to see the complete history of the truck before I go ahead and purchase it, so I will definatly be using that. So for now I guess I will just keep reading and looking.
Old 09-13-2006, 09:10 AM   #29
foreman00081
IM MIKE D
Member ID: 50102
cool, ya, best thing to do is definetly do your research and know as much as you can before you get one, there is soo much to know about these trucks its insane and before you know it youll be hooked, then youll be dreaming about your truck at night and spending all your money on it!
