Old 09-28-2006, 06:30 PM   #1
michael leblanc
Member ID: 55706
Question Programmer-tires-exhaust help
Hi i am very new to this website and to diesel trucks. I will soon be getting a 2007 silverado 2500 with the duramax. I know almost nothing about diesel performance so please help. A few questions i have are:
1- Will i eventually have problems running a programmer tuned to more than 50 hp
2- will a cat-back exhaust be enough to lower egt's
3- will 33/12.50 tires fit with keys and minor trimming
4- thinking about an s&b intake- any comments
I plan on driving this truck for a long time without any problems so please any info will help.
Old 09-28-2006, 07:36 PM   #2
Zick
Member ID: 15311
Re: Programmer-tires-exhaust help
Not trying to drive you away from here but your best bet on finding info on this stuff is over at www.thedieselplace.com
They have tons of info over there.
Born on 11/20/06: '07 Classic GMC 2500HD DuraMax Edge Evo
SOLD-03' Silverado ECSB 6.0 LQ9, Patriot LS6 heads, TR230, 31lb inj, TB stall, vette servo, Corsa, HP Tuners
SOLD-99' Silverado ECSB 5.3
Old 09-28-2006, 07:38 PM   #3
Big Angry
Chest Poundin' Apes!
Big Angry's Avatar
Member ID: 349
1.Depends, some say the LBZ can limp the tranny stock, 50 might be the max. Will also depend on how you drive it.
2. Probably not. Kitty removal saw a nice drop in EGT's but not really the cat back part.
3. Yes, just keep an eye on wheel width and backspacing.
4. Nope.
2004.5 Chevy CCSB D/A LLY
Old 09-28-2006, 08:29 PM   #4
dozerboy
dozerboy's Avatar
Status: Online
Member ID: 25211
I wouldn't add any power stock trans there is a "shift kit" called transgo Jr. made by TTS converters that should let you run some extra power. I though there was like a 100* drop from a cat back, but maybe not? Wheel BS is key for 33s look for 5" or so H2 takeoffs are good replacements. There is nothing wrong with the stock intakes on the 06s I would leave it, but if you want an aftermarket s&b intakes would be my choice from what I have read. Joining DP would be wise secondary fuel and oil filters, pitman and idler arm braces, and tie rod sleeves are wise investments if your going to take your truck to the grave.
Old 09-28-2006, 08:45 PM   #5
Big Angry
Big Angry's Avatar
Member ID: 349
Dozer, there might have been a slight dip in EGT's, but if it was, it was hardly noticeable, but when I straight piped the front pipe, that made a big difference.
Old 09-28-2006, 09:03 PM   #6
michael leblanc
Member ID: 55706
thanks for the help, i guess i can do with out the programmer then if i would be risking limping the tranny or causing other damages
Old 09-28-2006, 09:04 PM   #7
Big Angry
Big Angry's Avatar
Member ID: 349
You say that now...but once the modding starts, it's worse than a bad crack habit....
Old 09-28-2006, 10:02 PM   #8
michael leblanc
Member ID: 55706
ok well if i were to buy the preadator progrmmer, and only use the 40 hp tune, would i be safe with egt's, and tranny
Old 09-28-2006, 10:20 PM   #9
Big Angry
Big Angry's Avatar
Member ID: 349
Should be, just don't beat on it too hard.
Old 09-30-2006, 12:24 AM   #10
michael leblanc
Member ID: 55706
thanks again for the help, how long should i wait to but these mods on, by this i mean how many miles should the truck have before being totally broken in, and is it true that the allison can actually learn or reprogram itself to the newly added power?
Old 10-02-2006, 10:22 PM   #11
dozerboy
dozerboy's Avatar
Status: Online
Member ID: 25211
Do them now if you want diesel take a good 10-15K to break-in. Yes so take it easy for a little while on the new power and let the tranny learn. If you can keep it on the 40 setting your tranny should last a while the best thing to do is keeping your foot out of it in above 4th gear and burnouts and boosted launches should be avoided with power added.
