Old 01-10-2007, 08:59 AM   #21
LostBoy
All That Is Man
LostBoy's Avatar
Member ID: 21194
Re: 12v cummins
If you're going to turn up fuel delivery that much, it needs to be matched w/ a higher flow turbo to get all the power out of it & to keep EGT's down
Old 01-10-2007, 08:23 PM   #22
Big Angry
Chest Poundin' Apes!
Big Angry's Avatar
Member ID: 349
Re: 12v cummins
Originally Posted by blackbike82
At my old work they turned up the IP a lot. They had a lot more power. However, this would cause the exhaust temp levels to be insane. Also they would pour out the smoke. They also turned up the turbos to put out 30-40lbs of boost. I don't know exaclty how they did this but all I know is they hauled A$$. You have to get a Pyrometer to be safe. With a trailer exhaust temps would get into the 1200+ range easy. When you get up to 1000 deg you pretty much had to let completely off the throttle to let it cool. When you stopped you also had to let them run about a minute to get the exhaust under 500. If i remember correctly they had them both dynod the 92 was 275hp and 1200 tq yes 1200. The 93 was 375hp and 576 tq.
They had the power but you couldn't use it towing. The 93 even had dual 5inch exhaust to help but it was minimal.
Wow, are you sure about those numbers? I have never seen a pick up truck that had 4 Times more torque than horsepower. It's usually about a 2:1. 4:1 is pretty much unheard of.
2004.5 Chevy CCSB D/A LLY
Old 01-10-2007, 08:55 PM   #23
litespeed
The Shrimp Pimp
Member ID: 57224
Re: 12v cummins
Not really.... The stock Cummins ISX 385 Puts out 385 HP and 1450 to 1550 lbs. of torque respectively. Depending on the configuration in the truck.
I would not believe it until I saw it a few times on the dyno. Pretty amazing... Not on the ISX but on the ISB in pick ups.
1996 Chevy K1500 Z71 ECSB 166,000 miles
5.7, 4L60E, 3:42 G80, 1500HD leaf spring conversion, Nerf bars, Rhino Liner, Roll.n.Lock
Old 01-10-2007, 09:03 PM   #24
Big Angry
Big Angry's Avatar
Member ID: 349
Re: 12v cummins
What pickup does the ISX come in? I guess I should have specified I was talking about pick up trucks, with engines that came stock in them. I realize that med. duty and heavy duty trucks are different beasts, but he was talking about a 92 12v, and I sorta was too.
Old 01-11-2007, 03:21 PM   #25
litespeed
The Shrimp Pimp
Member ID: 57224
Re: 12v cummins
The ISX is not available in pickups. It is not uncommon to see almost 5:1 numbers out of a Cummins. I have seen it on the dyno a few times. The 12 valve is known for making gobs of power. And doing it more easily than a 24 valver (like the one I had). I should have used a better example. I apologize for that.
Here is a 1996 for sale with the dyno sheet. 248 HP and 1300 FT. LBS. of torque.
http://albuquerque.craigslist.org/car/254733583.html
Old 01-11-2007, 06:57 PM   #26
Big Angry
Big Angry's Avatar
Member ID: 349
Re: 12v cummins
Wow, I know the legend of the 12Valve, but I don't realize there was such a huge gap in the torque to Hp ratio. That is a ton of torque. Still seems like a huge gap to me, (I have difficulty accepting things some time). Thanks for the info.
Old 01-11-2007, 07:05 PM   #27
SteppinLo
Member ID: 29674
Re: 12v cummins
I think the Cummins 5.9 makes about two foot pounds of torque for every horsepower. Mine is close to that! The NV manuals and Dodge autos will not live with the kind of torque that is being reported in some of these posts.
"96 ECSB Totalled 11/06 "99 ECSB K1500 5.3 Base Silverado with 320K miles on the clock "01 GMC CCSB K2500 6.0 153K with 19.5" Michelin Medium Duty Tires "95 Cummins TD 310/751
Old 01-13-2007, 02:35 PM   #28
FarmTruckin
CTD
Member ID: 61439
Re: 12v cummins
www.turbodieselregister.com Is another good Cummins Information site...actually one of the Best Cummins Information sites being its fully devoted to Cummins...
Old 01-13-2007, 08:53 PM   #29
litespeed
The Shrimp Pimp
Member ID: 57224
Re: 12v cummins
Absolutely! That is an invaluable resource for Cummins owners. I have been a member there for a few years.
