Old 11-04-2006, 01:36 AM   #1
Matt03duramax
Member ID: 57840
oil pressure problem
My 03 duramax 6.6L oil pressure is all over the place from 40psi to 80psi while running down the highway and then occationally when iddiling it will drop low and give me a low oil pressure
on the warning light where the odometer reads.
any one have any ideas what might be going on? possibly something simple like the pressure sending unit?
how is the oil system set up on these? like what are they using for pump style, how is it driven, what is being used for a regulator, etc..
thanks.
Old 11-04-2006, 01:12 PM   #2
RandallH1989
RandallH1989's Avatar
Member ID: 50494
Re: oil pressure problem
Well if it helps at all, the oil pressure changes as your engine RPM's increase or decrease. However, I don't think it should be giving you the warning light while idling. I think I read you only need 7 PSI while idling. Search for "oil pressure" I think and find the thread that the guy had a similar problem. There is a list of what your oil pressure needs to read while at certain RPM's.
But yeah, no idea why it is fluxuating so much.
Displacement - When you need more than a soda bottle's worth of power.
Old 11-06-2006, 11:34 AM   #3
LostBoy
All That Is Man
LostBoy's Avatar
Member ID: 21194
How's your oil level? Type of oil (brand, synthetic or conventional, viscosity grade, etc.) Please don't take offense to the basic questions...
Old 11-06-2006, 07:50 PM   #4
dozerboy
dozerboy's Avatar
Member ID: 25211
If your oil level fine I bet it’s the sending unit or gauge/cluster.
Old 11-06-2006, 09:22 PM   #5
Matt03duramax
Member ID: 57840
I just got my duramax back from the dealership, they said the gauge cluster went out and replaced it. and said nothing was wrong with the oil pressure. but still the oil pressure drops while iddiling and low alarm comes in. while running down the highway with rpm stedy oil gauge is bouncing - back to the shop it go's. i think a different shop this time, to have the sending unit checked out.
oil level is at the full mark and has not changed. I am running
15W-40 conventional.
Old 11-09-2006, 08:54 AM   #6
TOTHEMAX!
TOTHEMAX!'s Avatar
Member ID: 55001
my cluster had to be replaced when i first got the truck. my pressure in the morning was over 120, and my speedometer would catch and bounce.
2003 Chevy SB CC Duramax Diesel
Edge W/Attitude Monitor
KD Boost Valve
Afe Stage 2 Air Intake
4" Magna Flow Turbo Back Exhaust
Bilstein Shocks
High Idle
1972 Chevy 3/4 Ton Project Truck
AMSOIL DEALER
Old 11-10-2006, 12:55 PM   #7
duratothemax
Member ID: 53120
minimum spec is 14psi hot at idle, and 42 psi hot at 1800rpm
'05 Silver-a-doo LT, CC/SB
Dmax/Ally
Old 11-16-2006, 08:48 AM   #8
Matt03duramax
Member ID: 57840
The sending unit was goig out and has been replaced. Thanks for your input
Old 11-16-2006, 09:11 AM   #9
LostBoy
All That Is Man
LostBoy's Avatar
Member ID: 21194
Thanks for posting back w/ the results
