#1 |
Member ID: 58660
Transmission slippage
I was wondering if any of you guys with the juice chip has noticed the transmission slipping. And do anyone know how much power you can safely get without transmission upgrades?
#2 |
Member ID: 46297
Re: Transmission slippage
what year dmax u got?
#3 |
Member ID: 58660
2005
#4 |
Member ID: 46297
i know on the earlier years of the d-max/allison you needed to get stiffer shift springs for your tranny but i think that was fixed in 04.
#5 |
All That Is Man
General rule of thumb is the stock Allison will hold about 100 ft-lbs of torque over stock output, so yes, that Juice w/ Attitude is certainly capable of causing a slip on the high settings.
When you say 'slip' are you just monitoring slippage on the monitor or actually going into limp mode?
#6 |
Member ID: 25211
Some slip on the EM is normal level 2 is safe 3 is pushing it.
![]() These views expressed on this post are not my own, but rather randomly generated computer gibberish and in no way should be used to judge the author's IQ or mental health. |
#7 |
i run mine of lvl 3/5. i think its just luck of the draw when it comes to tranny's. some guys run their ally hard all the time on lvl 4 0r 5 and never have a problem (but its just a matter of time) other guys run on lvl 3 and mess up the tranny. i think if you drive it normal/lite on the lvl you are planning on running you will be better off if you get on it hard from time to time. this gives the allsion time to learn the higher power so its not such a shock to the system. it is a big shock if you just crank it up to lvl 5 and give her hell.. just my 2 cents
2003 Chevy SB CC Duramax Diesel
Edge W/Attitude Monitor KD Boost Valve Afe Stage 2 Air Intake 4" Magna Flow Turbo Back Exhaust Bilstein Shocks High Idle 1972 Chevy 3/4 Ton Project Truck AMSOIL DEALER |
| Advertisements |
| Thread Tools | |
| Display Modes | |
