Old 03-28-2007, 11:58 PM   #1
gmc stroker
gmc stroker's Avatar
Member ID: 61932
rumor or fact?
I have herd a rumor numerious times that in the near future the truck companies will have a pcm that will recognize any aftermarket tuner and will not allow the truck to start unless it is back to a stock setting? if this is true either the chip makers are gonna have to get crafty or there isnt gonna be jack for the new trucks. If this is true im guessing the price of tuners are gonna be much more expensive
Old 03-29-2007, 12:51 AM   #2
WhiteBrow24
I have a White Eyebrow
WhiteBrow24's Avatar
Member ID: 56643
Re: rumor or fact?
where did you hear this? as this is the first i have herd of such a thing.
Brian Threet 3-17-87 - 1-05-08
Jenna Foellmi 9-15-87 - 12-14-07
I feel you everywhere I go, I see your smile, I see your face, I hear you laughing in the rain, I Still can't believe you're gone.
Old 03-29-2007, 05:51 AM   #3
Silverad04
Silverad04's Avatar
Member ID: 57641
Re: rumor or fact?
I don't think so. That would just be retarded on gm's part.
2004 Silverado-RCSB-5.3-Pacesetter LT's-DynaTech Cats-X Pipe-Dual Bullets-Volant-LS1 E-Fans-PCM Tune
2005 Cavalier 5 speed-The 2.2 BEAST!!!
Old 03-29-2007, 08:19 AM   #4
strictlydiesel
strictlydiesel's Avatar
Member ID: 59200
Re: rumor or fact?
i think furd psd is doing that. i might be wrong though.
1994 GMC ExtCab*4x4*6.5L TD*4L80E*B&M Shift Enhancer*SSDS 80hp Chip*EGR Blockoff*Remote PMD*#9 Resistor*Optic Bump*3 Gauge Pillar*VDO Boost,Pyro,Tranny Gauges*4" Straight Pipe Exhaust*Turbo Master @ 15psi*Cold Air Intake*ATA Intercooled*5" Lift*14 Bolt SF*3.73*LT285/75-R16 Buckshot Mudders
Old 03-29-2007, 12:12 PM   #5
Mark13
I'm so much cooler online
Mark13's Avatar
Member ID: 58067
Re: rumor or fact?
I heard something along the lines as that also. I believe it was about the 6.4L
Thanks 454ss
98 K1500
03 suzuki z400
Originally Posted by 44gmcnewf
I know my truck is a girl ... she talks to me. Shes a bit bitchy and skanky but im ok with that.
Old 03-29-2007, 01:04 PM   #6
87Iroc
87Iroc's Avatar
Member ID: 10554
Re: rumor or fact?
All vehicle manufactures are looking into this I am sure.
A major warranty cost(at least Cummins believes this) is for folks that put aftermarket components on the trucks that cause damage to the engine or driveline. They then pull them off and get warranty work done and put them back on.
I am not 100% familiar with these products, but I am guessing this might be a rough example... say someone has a several stage box from like Bully Dog(I don't even know if they make one) and they do something that Bully dog never even intended(like cranking timing too much or cranking fuel up while other parameters are wrong(not sure if this is possible on most companies components..but I am sure it is possible on some)) and it causes damage to the engine. They screwed up, but they take everything off and go to the dealer and it gets fixed under warranty. Should the OEM have to pay for that persons screw up? I don't think so and neither do the OEMs.
I know Cummins has looked into ways to defeat the aftermarket before. It is still being looked in to as a major warranty expense is what I stated above.
I am also sure, as soon as a manufacturer comes up with something to defeat this, the aftermarket will get crafty and work to defeat it as someone stated previously.
GregF
87IROC
2000 Z71
Old 03-29-2007, 04:21 PM   #7
WhiteBrow24
Member ID: 56643
Re: rumor or fact?
let them try it. just like everything else there is a back door around it
Old 03-29-2007, 04:41 PM   #8
KickAss89chev
Registered Woman Pleaser
KickAss89chev's Avatar
Member ID: 43619
Re: rumor or fact?
make tuners only available through the stealerships would be better, but then thered be the few poeple sneaking em out and stuff, lol
1981 Monte Carlo, dual pipes,FOR SALE
1985 Monte Carlo. Dual exhuast on a mild built 350. T Tops
Old 03-29-2007, 05:16 PM   #9
Blaze5509
hippies hate deathmetal!
Member ID: 31439
Re: rumor or fact?
If they just had some sort of DataLogging they could tell what parameters have been messed with and see if it is a warranty issue or a user error on the tuning.
I know most PCMs are locked and people have a hard time editing them...Hemi's...Titans and the like.
Thnx 9chevy4
Originally Posted by 1989K1500
And if he didnt spaz on you while you where balls deep in his daughter he probably wont flip on you at all.
Old 03-29-2007, 06:04 PM   #10
gmc stroker
Member ID: 61932
Re: rumor or fact?
my family owns a diesel shop and various customers have asked ?s about it
Old 04-02-2007, 08:16 AM   #11
TOTHEMAX!
TOTHEMAX!'s Avatar
Member ID: 55001
Re: rumor or fact?
i side with the manufactures on this one. they should not have to pick up the bill when people are adding insane amounts of hp and destroying stuff. you got to pay to play! people just need to pony up and learn some responsibility
2003 Chevy SB CC Duramax Diesel
Edge W/Attitude Monitor
KD Boost Valve
Afe Stage 2 Air Intake
4" Magna Flow Turbo Back Exhaust
Bilstein Shocks
High Idle
1972 Chevy 3/4 Ton Project Truck
AMSOIL DEALER
Old 04-03-2007, 08:38 PM   #12
dozerboy
dozerboy's Avatar
Member ID: 25211
Re: rumor or fact?
X2 but when they void the warranty for over side tires and straight piped exhaust that is BS. If the mod truly cause the problem then if should be your $$$ to fix it.
Old 04-03-2007, 09:53 PM   #13
WhiteBrow24
Member ID: 56643
Re: rumor or fact?
i think they need to get the computers to say why something broke. was there to much forced air? was there not enough back pressure? the computer should be able to give more information, then just whats wrong. I mean look at the day in age we live in, all the amazing things they can do with computers these days.
Old 04-04-2007, 09:40 AM   #14
LostBoy
All That Is Man
LostBoy's Avatar
Member ID: 21194
Re: rumor or fact?
I'm with dozer; it goes both ways, so retail customers pay a lot of money for problems that weren't their fault & should've been covered under warranty just like dealers pay for some repairs they shouldn't have to.
It's usually pretty obvious when somebody had something cranked up so high it caused a problem. They can lock down a computer all they want, that'll just eliminate tuners, not boxes. A box modifies computer output to get what it wants, then modifies input so the computer never sees what happened. The ECM already data-logs, but it has no way of knowing the data it's logging has been modified.
