#1 |
Member ID: 59600
SOMEONE please tell me about the 6.2L!!!!!!
I want to do a swap in my 75 k20 truck. I wanted to know if I bought one of these engine, and put a turbo on it, would it be reliable and put out more power than my almost stock 350? Will my th350 bolt up to an 85 6.2L off of a 2wd burban? Please tell me everything you know about these engines....good or bad?
Thanks
1975 Chevy K20 350 V8 TH350 6" Rancho/Rough Country Lift 35/12.5/16.5 BFG MT KM's on MODS True Dual exhaust
#2 |
Re: SOMEONE please tell me about the 6.2L!!!!!!
I guess I'll be the dick that tells you to search through these forums, the forums at the diesel place, as well as other GM truck forums. There is a wealth of information that has already been posted about these engines.
Personally, I think you are better off with a Cummins swap, but you'll have to do the research and decide which is best for your intended application.
2004.5 Dodge 2500 CTD - DD/Tow Rig
1991 K-1500 - Coil sprung 3-linked D60, 14FF, 38.5x11 Boggers, mostly stock |
#3 |
You're alot better off with a TBI 350 than those old diesel setups. back then, gas engines had more to them than the diesels. not so much today... because of the rise of the turbo diesel. but for that truck, i'd stay with the 350. If you want more grunt, get a 383.
#4 |
Member ID: 59600
I am going to go with a 6.5TD instead of the old technology. I think a 6.5TD will get the job well done. Thanks for all the help. The only reason I want to dump my 350 is A) it is old and sort of smokes B)It is gutless and I can hardly spin a tire (granted it is a 35" tire) and C) It is getting worn out and I could put it into an s-10 and have fun with it. Thanks
#5 |
How many miles did you put on your 350? Also... as for the gutless part... Your true duals might've been the culprit. They pretty well ruin your backpressure, and you DO need some of that for good torque.
#6 |
Diesel Member
Member ID: 59605
Get the 6.5L probably cost the same as a 6.2 in the long run. I never did like the 350 tbi unless it had a cam and some heads like edelbrock on it.
Real trucks don't have spark plugs! 2007 3500HD NBS Duramax 2005 2500HD Duramax sled puller 1996 1500 6.5L converted SVO/WVO 16city/22hwy 2000 malibu 3.1 vin J 2006 arctic cat prowler 650 H1 5th wheel 34' PJ flatdeck trailer Last edited by justy : 11-01-2007 at 04:48 PM. |
#7 |
Member ID: 59600
I have maybe 15,000 after rebuild like 20 years ago....it just sits around. I never drive it. Not that much anyway. I put 25 miles on it during summer. I need the duals, I have a high duration cam. I can burn out. Really, it is just old. The engine is old, the parts are old, it will sometimes smoke. It also still has the stock exhaust manifolds. I might as well buy some new headers. Just curious, what kind of mpg should I be getting only driving like 4 miles a day. I live about 2 miles away from my school. Thanks
#8 | |
Like cocaine and waffles
Not that good, it doesnt have time to warm up befor you shut it down so its gonna be burning a bit richer than if it were up to temp |
#9 |
Member ID: 59600
My brother told my like 6 or 8. I am not sure if I believe him though. He said he put like $20 on monday morning (2 years ago)
$20/$2.50 = 8 gallons. 4 miles a day x 5 = 20 miles. 20 miles/8 gallons = 2.5mpg....I doubt that.
| Advertisements |
| Thread Tools | |
| Display Modes | |
