Old 10-30-2007, 06:07 AM   #1
Snocross418
Snocross418's Avatar
Member ID: 72260
Amsoil Question?
I talked my Grandfather into running Amsoil in his 2002 2500 Duramax with 38K. I'm getting ready to order it and I'm not sure if I should get the-
15W-40 Heavy Duty Diesel Oil
10W-30/SAE 30 Heavy Duty Diesel Oil
5W-40 Premium API CJ-4 Diesel Oil
What do you run?
2007 Z71 Silverado Crew Cab Blue Granite Matallic
2.5" Leveling kit, Chevy Tanoue cover
AMSOIL DEALER
Past
2005 Z71 Ext Cab
2001 Z71 Ext Cab (with a piston slappen 5.3L!)
1999 Z71 4dr Hoe (the babe wagon!)
Old 11-03-2007, 02:44 AM   #2
dddonkey
Member ID: 76154
Re: Amsoil Question?
I run the 15W-40 Heavy Duty Diesel Oil. I have run it for a while now.
Old 11-03-2007, 06:42 AM   #3
justy
Diesel Nut
justy's Avatar
Member ID: 59605
I ran 15W-40 all winter last year no trouble. Although I have a heated garage which helps.
2007 3500HD NBS Duramax
Old 11-03-2007, 09:10 PM   #4
dozerboy
dozerboy's Avatar
Member ID: 25211
X3 But IMO its over rated I would use Chevron Delo 400.
Old 11-05-2007, 11:56 AM   #5
TOTHEMAX!
TOTHEMAX!'s Avatar
Member ID: 55001
15w-40 is great for temps over 0.
if he lives where it gets below 0 quite often then you could run the 5-30 hdd. it provides the same protection as the 15-40 just better in the cold. i ran it last winter and loved it when it was cold out. started great
2003 Chevy SB CC Duramax Diesel
Edge W/Attitude Monitor
KD Boost Valve
Afe Stage 2 Air Intake
4" Magna Flow Turbo Back Exhaust
Bilstein Shocks
High Idle
1972 Chevy 3/4 Ton Project Truck
AMSOIL DEALER
Old 11-05-2007, 01:12 PM   #6
Tom S.
Driving 4x4's since 1973
Tom S.'s Avatar
Member ID: 76222
Since you live in Michigan, go with the 5w-40. It will turn over much easier when the temps drop. I run 5w-40 year round, but not Amsoil. Since I travel a lot, I use Mobil 1 because its much easier to find on the road.
2006 LBZ 3500 HD
Single Rear Wheels
Press 1 for English - Press 2 to learn English - Press 3 for Immigration
