Old 11-08-2007, 01:26 PM   #1
OldBlue85
Member ID: 73775
need help
how hard is it to replace an injection pump on a 6.2L? I priced one and its $400 so im hoping its worth it. still starts up fine and everything but once its warmed up and u shut it down its a nightmare to start back up
06 kawasaki KFX 400
2007 chevy 3500 DURAMAX/ALLY crew cab long bed 4x4
Seabees
Old 11-08-2007, 05:48 PM   #2
ZsevneeONE
Member ID: 56490
Re: need help
i couldn't explain the steps in my own words so i found this far ya from a service manual.............."Changing an injection pump on a GM 6.2L Diesel is not as difficult as one might expect. Getting to the injection pump requires removing the air cleaner assemble and the intake manifold. Before the manifold can be removed, several brackets may need to be loosened and removed from the studs that hold on the intake manifold. This may include the air conditioner condenser bracket and alternator bracket. Be sure and note the location of the studs and the lengths of the bolts so that they can be reassembled in the proper holes. Once the intake manifold is removed it’s a good idea to remove the vacuum pump. This allows enough room for the injection pump to be removed with the injection lines attached. Loosen the injection line brackets and take the injection lines from each injector. Next, remove the oil fill spout from the front of the engine exposing the pump drive gear. Bar the engine over until a bolt is exposed and can be removed. There are 3 bolts that hold the drive gear to the pump but they can only be removed one at a time so after each one is removed the engine should be barred over until the second bolt can be removed and then a third time to expose the last bolt. Once these three bolts are removed the fuel line should be removed. Then the 3 nuts that hold the injection pump on can be removed and the injection pump slid toward the rear of the engine. The pump has to be moved far enough that the button in the center of the drive shaft will clear the engine. Be careful of the glow plug wires and make sure not to hang on one of them. Once the pump is removed note the location of the timing pin in the pump drive (such as 4:00 o’clock position) this will help when reinstalling the pump to the engine."
Old 11-08-2007, 08:07 PM   #3
justy
Diesel Member
justy's Avatar
Status: Online
Member ID: 59605
Re: need help
Becareful with that fuel stuff, some of it is under pressure. Can easily cut through skin and body tissue.
2007 3500HD NBS Duramax
2000 malibu 3.1 vin J
Old 11-09-2007, 08:43 AM   #4
OldBlue85
Member ID: 73775
Re: need help
ok, I was told if I replaced the pump that I would also have to go and replace the lines and injectors. how long could I get by without doing that?
06 kawasaki KFX 400
Seabees
Old 11-10-2007, 11:34 AM   #5
ZsevneeONE
Member ID: 56490
Re: need help
i would replace it all that way you won't have to deal with it for a while
Old 11-10-2007, 03:20 PM   #6
FordeatinZ71
FSC Drunkin Teem
FordeatinZ71's Avatar
Member ID: 2427
Location: Hooks, Texas...i keep working closer and closer to 'Bama!
Re: need help
these pumps aren't hard to change. just follow the instructions ZsevneeONE posted. oh, and when you are reinstalling it, be careful. in the timing gear (the injector pump drive gear), there are TWO holes the pin can fit in...you want the OVAL shaped hole...not the round one. it will not bolt in right if you put it in the round hole...it's not a hard job though. and as for replacing the lines...sure, you could, but when i did injector pumps (the SAME ONES) on the military Hummers, we NEVER changed the lines unless we had a bad one that leaked...
<---thanks 454SS!!
1991 Chevy Silverado K1500 extended cab, 350, 700R4 with shift kit, exhaust work...in need of body work...lol...
1983 GMC Sierra K1500 sold...
