Old 03-24-2008, 08:57 AM   #1
smit
Member ID: 86154
2500 6.5 turbo diesel problem
I've had a problem for about 3 months now i can't seem to get sorted so was wondering if anyone could offer some advice / ideas please?
I have 1997 2500 6.5 diesel turbo.
It started cutting out whilst driving and is now at the point where you could driver for hours with no problem or it would run for just a few seconds if at all.
Things that have been done are
New fuel filter
New inline fuel pump
New cutoff switch
Drained the tank
New fuel relay
HELP please
Smit
Old 03-24-2008, 10:03 AM   #2
vegaman04
1 Twisted User
vegaman04's Avatar
Member ID: 59479
Re: 2500 6.5 turbo diesel problem
Sounds like the PMD is on its way out the door.
96' K2500HD 6.5l TD, Heath PMD, Turbo Master, Mand. Bent X-Over Pipe, 4" Flo Pro Exhaust, Vac Pump Removed Belt # 4061000 = 100", 04' Dmax wheels w/ 265's
99' Silverado 5.3l Z71, 265's with Cooper STT's
Old 03-24-2008, 03:22 PM   #3
smit
Member ID: 86154
What is PMD ?
Old 03-24-2008, 09:01 PM   #4
vegaman04
1 Twisted User
vegaman04's Avatar
Member ID: 59479
Pump Mounted Driver aka Fuel Solenoid driver, its located on the injection pump and it controls the amount of fuel. Its a common issue on these motors. Heat is the main cause of failure. Ebay has relocation kits, as well as other suppliers. Best place to move it out of the engine bay. Heath Diesel has a nice kit but with a price but comes with a great warranty and service. Do a search on here and look around and you'll find some more info.
Old 03-25-2008, 01:53 AM   #5
smit
Member ID: 86154
IS that not the fuel cut off switch then? Mounted at the front center of the engine?
Anyone got an image of the part please?
Old 03-25-2008, 03:58 AM   #6
smit
Member ID: 86154
http://cgi.ebay.com/ebaymotors/GM-6-5-Diesel-FSD-PMD-Super-Cooler-and-Extension-cable_W0QQitemZ300208342306QQcmdZViewItem?hash=ite m300208342306
Is this the kiddy?
Old 03-25-2008, 04:42 AM   #7
Dupontster
Earth is full...Go home..
Dupontster's Avatar
Member ID: 7138
I had a 98 6.5 with the same symptoms...Hate to tell you this but an new injector pump fixed it....$$$$$$$ Yours may not be the same problem but like I said, it fixed mine...
"I love to go to the schoolyard and watch the children jump and scream, but they don't know I'm using blanks."
Old 03-25-2008, 07:27 AM   #8
vegaman04
1 Twisted User
vegaman04's Avatar
Member ID: 59479
They might have also replaced the PMD while they were in there, i dont know for sure cause i didnt see the bill.
But anywho, that would work except you need a new PMD in combination with that. Get it out of the engine bay, ie behind the bumper or on the skid plate like heaths does. Heaths has an even bigger heatsink. Also give it some time for Chris to chime in or others to assess the situation.
Old 03-25-2008, 08:45 AM   #9
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Sounds like classic PMD failure. But...
When it stalls is it like someone turned off the key? Do you lose your dash lights? What 'cutoff switch' did you replace?
If it is the PMD (most likely) you will want to buy it from Heath Diesel. You will pay more for it there than anywhere else but Heath's PMD isolator kit comes with a 7 year warranty.
Do not buy 'tested' or 'used but good' PMDs off of Ebay. Remember, 3 months ago YOUR PMD was 'used but good'.
1/4 Mile ET
16.722 @ 80.701 MPH
Old 03-25-2008, 08:48 AM   #10
chrisk1500
chrisk1500's Avatar
Member ID: 28947
That's because there was a new PMD on the new IP.
A new PMD instead of a whole new IP would have saved you a pile of $$$$$$
1/4 Mile ET
16.722 @ 80.701 MPH
Old 03-25-2008, 09:34 AM   #11
smit
Member ID: 86154
http://www.heathdiesel.com/ <-- this guy then?
I'll give it a little more time for replys but i think i need to be on the phone ;)
Cheers for your help chaps
Old 03-25-2008, 10:23 AM   #12
vegaman04
1 Twisted User
vegaman04's Avatar
Member ID: 59479
Thats the one, got one my self and love it, breeze to install. Good luck and no problem thats why we're here.
Old 03-25-2008, 02:07 PM   #13
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Pick up the phone and ask for Ian.
Tell him that 'Chris from Canada' sent you...
1/4 Mile ET
16.722 @ 80.701 MPH
Old 03-25-2008, 03:33 PM   #14
smit
Member ID: 86154
http://www.heathdiesel.com/P/HDP1296/
This the bit then?
Old 03-25-2008, 03:44 PM   #15
vegaman04
1 Twisted User
vegaman04's Avatar
Member ID: 59479
It you got 2wd, thats the one you need.
Old 03-25-2008, 03:44 PM   #16
chrisk1500
chrisk1500's Avatar
Member ID: 28947
That is the one for 2WD trucks.
1/4 Mile ET
16.722 @ 80.701 MPH
Old 03-25-2008, 04:20 PM   #17
smit
Member ID: 86154
yep 2WD
Old 03-28-2008, 03:40 AM   #18
smit
Member ID: 86154
Part orderd cheers guys.
Just hope it sorts it.
Smit
Old 03-31-2008, 07:54 AM   #19
smit
Member ID: 86154
Well the part is fitted and just under the hood for the moment and waiting to see if it works or not.
Fingers crossed.
Old 04-01-2008, 01:55 PM   #20
vegaman04
1 Twisted User
vegaman04's Avatar
Member ID: 59479
Well, did it fix your problems?
