Old 04-28-2008, 06:27 PM   #21
dozerboy's Avatar
Re: Possible Diesel Combo In 1500
Originally Posted by thirdstreettito
because it is guaranteed to have low miles and have been taken care of.
Sure if you say so
dozerboy is offline
Old 05-07-2008, 01:53 PM   #22
GAsilver5.3's Avatar
Hehe I was a 63B (hummer mechanic) in the army for almost 6 years. I have to say no to the non-turbo 6.2. It has somewhere around the same eng. specs. as the newer 2.8. I've blown a few of those up before too. lol I have also tried to pull another Hmmwvee before and it was crazy slow even with the offroad gearing. Heck it even had a hard time going up normal hills on it's own. The Hmmwvee is a heavy truck though and it was full of parts and water and food and people and tools. I think my 5.3 has more torque by far though!
GAsilver5.3 is offline
Old 05-07-2008, 04:42 PM   #23
The allison trans is WAY to big for the 2.8L. You would be much better off using a 4L80E (probably still WAY to big for that engine). With the 4l80e you could use a TCI stand alone controller. Although i am not sure how you would rig up some of the sensors for it.
IMO the cummins 4bt and 4l80e combo sounds like a winner.
2007 Silverado Classic LBZ CCLB
Home of the 18 point U-Turn.
johndeerrm is offline
Old 05-16-2008, 01:55 PM   #24
I am looking into the isuzu 4bd2tc swap. Could my stock LS1 pcm be edited to still control my 4l60e, haeat, A/C and other stuff? Any ideas?
www.isuzudieselswapper.com
Brad
dagwood is offline
Old 05-16-2008, 08:32 PM   #25
Diesel Nut
justy's Avatar
I think to do that you'll need a stand-alone controller for the transmission. Hard to say. I haven't done that swap yet. That would be a alright engine to use if you can find a adaptor plate for it. Cummins you can find adaptor plates a dime for a dozen.
2007 3500HD NBS Duramax
justy is offline
Old 05-17-2008, 07:56 AM   #26
What else does my PCM control other than the engine and trans? When I took it in for a HVAC noise, the tech said there was a software update to stop it. Does the PCM control the HVAC too?
Brad
dagwood is offline
Old 05-18-2008, 12:39 AM   #27
A military truck won't necessarily be guaranteed to have low miles, and more then likely it will have been beat up.
But sometimes you can find a good one.
kcb37 is offline
Old 05-18-2008, 12:49 AM   #28
....used to have a 2 door
99-2door's Avatar
If I were you I would swap in an old 6.2L GM diesel from a military truck because it is guaranteed to have low miles and have been taken care of.
Easy there, anymore zingers like that and this thread will get moved to the "clownin' around" section.
2001 C3 6.0 AWD, 3/4 drop, DDU grille, Volant intake, flowmaster exhaust, pulleys, 05 e-fans, shaved tailgate handle, rollpan...tuned by ME.
2003 Tahoe Z71 5.3L, Silverado clip
1995 K3500 SRW..L31, 4L80e, 14bff
99-2door is offline
Old 05-18-2008, 05:54 PM   #29
Diesel Nut
justy's Avatar
Well I don't know if this will answer anything. But when I helped a friend with his 6bt swap. We used some of the sensors like oil sensor, water temp sensor and I think he used a tuner to delete or disabled a bunch of stuff. But in short he's still using the original pcm. Which basically runs nothing more then the transmission 4l80e. I believe his abs brakes still work as well. So you might be alright there if you can do that.
justy is offline
Old 05-19-2008, 09:33 PM   #30
Could you give me more details on the 6bt swap? What year truck? Difficulties?
Brad
dagwood is offline
Old 05-20-2008, 07:40 PM   #31
Diesel Nut
justy's Avatar
He put in a 93 cummins 5.9 into a 1998 Chevy k2500. He got most of his parts off the Internet, adaptor plate for transmission, engine mounts. He went to the junk yard got a used torque converter for $75. We basically unplugged the wiring. Pulled the Chevy 350 out which was broke from piston slap and broke a piston rod. Changed engine mounts, put new adaptor plate on. Put starter in that came with adaptor plate. Changed torque converters. Dropped 6bt in hooked up tranny and engine mounts. Hooked up sensor wires and ignition. He got a diesel tank and radiator off a 97 Chevy 2500 which took a hour to put on. After that he had it running the next mourning. He had a exhaust shop put the exhaust on and thats about it, other then him doing a few things with his tuner. I wasn't there when he did that. I just helped get the engine in. He uses that pickup to tow a steam engine tractor to tractor shows in minnesota, south and north dakota, wisconsin and iowa. He wanted a duramax but couldn't afford it so this swap was his idea. He's ran both bio-diesel and regular diesel in it with no troubles.
justy is offline
