Old 05-11-2008, 01:08 AM   #1
chevynorway
Member ID: 84645
just some questions
whoat is the difference between "F" and "S" engine on a 99?
Old 05-11-2008, 01:58 PM   #2
justy
Diesel Member
justy's Avatar
Member ID: 59605
Re: just some questions
I think in my c/k chevy manual the horsepower is different between S & F engines. Also can't remember but a 1/2 ton diesel engine had less horsepower then the 3/4 diesel. I gotta look in my book now and see what it is.
2007 3500HD NBS Duramax
2000 malibu 3.1 vin J
Old 05-11-2008, 02:05 PM   #3
justy
Diesel Member
justy's Avatar
Member ID: 59605
Well according to this book, Both diesel F & S are 180hp @ 3400 Rpms. The engines are the same, But it indicates F came with a TD/HO or no turbo. Which I find hard to believe on a 1999 model. HO stands for high output. But as far as specs they are same engine, same horsepower, same torque band. S came with a TD (turbo diesel).
Old 05-11-2008, 02:13 PM   #4
99-2door
Heck Yes I Did!
99-2door's Avatar
Member ID: 28587
The one in the 1/2 tons had an EGR valve in the upper intake and the HD one doesn't. Can't remember which is which letter.
2001 C3 6.0 AWD, 3/4 drop, Volant intake, flowmaster exhaust....in progress
2003 Tahoe Z71 5.3L, Silverado clip
Old 05-11-2008, 02:17 PM   #5
justy
Diesel Member
justy's Avatar
Member ID: 59605
That very well could be something with the egr. I didn't think of that.
Old 05-12-2008, 04:27 AM   #6
chevynorway
Member ID: 84645
i checked my vin number on the net and it says 255hp?? thougt it was 195.. are theese blocks likely to crack? mine has 240k km on it..
Old 05-12-2008, 04:56 AM   #7
daustin
daustin's Avatar
Member ID: 78706
The difference in the F and S is the EGR and a slight tuning difference. The 1/2 ton 1500's usually got the S staring in the 1994 model year. The 6.5 TD's are rated anywhere from 210HP ('92-93) down to 180HP (S later models). The F is usually in the 2500/3500's and some Suburbans, lots of people trash the S upper and lower intakes and replaced them with the F intakes. The F intakes don't have the EGR ports and that's blocked off in the lower intake. The F upper intakes aren't tapped for the EGR as well. Hope that helps.
Don
1993 Chevy 3500 6.5TD, 4.10 posi,
3" downpipe, GM-8 13psi max, Round Airbox mod, Straight Exhaust, 4911 turned up 1/4, Boost/pyro/trans instr,
'69 RS Camaro, '68 COPO 427 Vette
Old 05-12-2008, 10:24 AM   #8
justy
Diesel Member
justy's Avatar
Member ID: 59605
255 hp that would be a chevy 350 vortec lol. I could see 195 hp. The diesel 6.5 hovered around that horsepower range. If your diesel is a 195 it will have a little more towing power then a 454 tbi. They had trouble with cracking when the 6.5 first came out, gotta get it pretty hot. But that was solved within the first 2 years. If you vin # does say it's a gas engine, Then I would say someone put a diesel swap in it.
Old 05-13-2008, 08:56 AM   #9
chevynorway
Member ID: 84645
maybe..its a 4l80e tranny in it.. do the engine need to get wery hot to crack? like realy boiling? iwe been towing realy heavy loads up the mountains (8-9%) and no probs.. ..just dont want to end up with a cracked block:/
Old 05-13-2008, 10:15 AM   #10
DarkCharisma
total smartass #1
DarkCharisma's Avatar
Member ID: 72673
If you're worried add some additional cooling. I've read of some people on dieselplace adding aux. fans and larger radiators on their 6.5's.
'00 ECSB 4x4 | Built 4L65e | 5.3 | 2% Tint | K&N | Magnaflow | BFG | Wait4Me
Old 05-13-2008, 02:18 PM   #11
justy
Diesel Member
justy's Avatar
Member ID: 59605
I agree. I don't think you'll have a overheating problem. But you could always add a bigger radiator and high volume water pump. I never had to tow in the mountains. So I never worried about that. We have a few big hills here. Never trouble on those. But if you want to upgrade. I say go for it. But if you have winter where you are at. Make sure you have some type of grille cover. That will help it heat up when it gets cold. Then you'll have some actually heat from the heater. And the wife won't complain that she can see her breath.
Old 05-13-2008, 02:50 PM   #12
chevynorway
Member ID: 84645
have some realy cold winters here:) but in summer it can be up to +25degree celcius.. have never heard the cooling fan start though..and the engine temp just a little over normal up the hills..some told me the 99mod 6.5 block are likely to crack? or are these people just having wery bad luck? i push the engine hard on the hills..still runs great..my old `yota died from half of it..just started using oil..
Old 05-13-2008, 05:28 PM   #13
vegaman04
1 Twisted User
vegaman04's Avatar
Status: Online
Member ID: 59479
Since when did these trucks have electric fans? I dont think they do. Thats one of the upgrades for more power.
96' K2500HD 6.5l TD, Heath PMD, Turbo Master, Mand. Bent X-Over Pipe, 4" Flo Pro Exhaust, Vac Pump Removed Belt # 4061000 = 100", 04' Dmax wheels w/ 265's
99' Silverado 5.3l Z71
