#1 |
Member ID: 75767
Drw/srw
I have posted about buying a truck before, but I have another ?
I have an 89 Camaro and a 49 F-1. Right now I have a 20 ft open trailer. I know drw's is over kill along with the D-max. But in the long run I would like a gooseneck that I can put both in or one of the RV's that I can put one in. Will the drw's make that much of a diff pulling a dual car enclosed/ rv,car trailer? I do want a crew cab, and was thinking drw cause I know they are more stable. I do also like to go overkill when towing. ![]() 96 Silverado ECSB, 350, 4L60E, 3.42 G80 89 Camaro, 5 speed, 3.08 LS 49 F-1, flathead 6, 4 speed, 2wd, unknown rear end. Old rust bucket. |
#2 |
Diesel Member
Member ID: 59605
Re: Drw/srw
duel's will be a little more stable, Alot more stable if you have a 5th wheel trailer. But if you tow using regular trailer hitch. single wheel or dual are pretty close to the same. You should have a receiver hitch with sway bars. Then single or dual are the same. Or pretty close. I use a set of sway bars on the dually too, so it's good insurance having it. But basically. A 5th wheel trailer is where the single wheel and duals are different. Duels makes it alot more stable in the wind and such.
Real trucks don't have spark plugs! 2007 3500HD NBS Duramax 2005 2500HD Duramax sled puller 1996 1500 6.5L converted SVO/WVO 16city/22hwy 2000 malibu 3.1 vin J 2006 arctic cat prowler 650 H1 5th wheel 34' PJ flatdeck trailer Last edited by justy : 05-10-2008 at 01:42 AM. |
#3 |
Driving 4x4's since 1973
Member ID: 76222
Re: Drw/srw
I'm not sure how often you would run into a situation where it would make a large difference stability wise. I have pulled my 5th wheel from Maine to Alaska, and many points in between and never had any issues with my 3500 SRW.
Duals do give a larger carrying capacity, although to look at the "official" stats they dodn't look that different. Compare 4 tires with a 3000lb rating each vs 2 with a 3600lb rating each. I chose a SWR because I didn't want the hassle of having the extra rear width, and because it's expensive enough to replace 4 tires let alone 6.
2006 LBZ 3500 HD
Single Rear Wheels Press 1 for English - Press 2 to learn English - Press 3 for Immigration |
#4 |
Member ID: 25211
Re: Drw/srw
It you don't get one with living quarters so it isn't to tall you should be ok with a SRW, but DRW is better. If you would rather be overkill then a DRW is for you.
![]() These views expressed on this post are not my own, but rather randomly generated computer gibberish and in no way should be used to judge the author's IQ or mental health. |
#5 |
Member ID: 75767
Re: Drw/srw
When I get it I know it's going to be overkill for my trailer, but after I buy this truck I have no intention of getting rid of it for a long time. With plans of a dual enclosed or rv with car trailer I think I will go DRW.
Thank you for you imput. ![]() 96 Silverado ECSB, 350, 4L60E, 3.42 G80 89 Camaro, 5 speed, 3.08 LS 49 F-1, flathead 6, 4 speed, 2wd, unknown rear end. Old rust bucket. |
#6 |
Member ID: 76222
Re: Drw/srw
Either way, except for the price of diesel, you'll be happy with how it tows.
For additional questions and information try these sites: http://www.dieselplace.com/forum/index.php? http://www.dieseltowingresource.com/
2006 LBZ 3500 HD
#7 |
Member ID: 78706
Re: Drw/srw
I also pull a car trailer several times a year, with 60's-70's muscle cars. It's a 24' open dual-axle trailer, about 2500lbs empty. With one of the 60's cars usually about 6500lbs more or less depending upon what i have on it. I pulled with a SRW for years, i got a DRW in 2006 - now that i've pulled with the DRW i'm spoiled and won't use my SRW truck for that again if i can help it. No comparison on the stability on winding roads or high wind areas. My 2 cents worth.
Don
1993 Chevy 3500 6.5TD, 4.10 posi,
3" downpipe, GM-8 13psi max, Round Airbox mod, Straight Exhaust, 4911 turned up 1/4, Boost/pyro/trans instr, '69 RS Camaro, '68 COPO 427 Vette |
#8 |
Diesel Member
Member ID: 59605
Re: Drw/srw
Wish I had a trailer with old cars on it, Something that would make the duramax work. But the wife wouldn't let me do that.
Real trucks don't have spark plugs! 2007 3500HD NBS Duramax 2005 2500HD Duramax sled puller 1996 1500 6.5L converted SVO/WVO 16city/22hwy 2000 malibu 3.1 vin J 2006 arctic cat prowler 650 H1 5th wheel 34' PJ flatdeck trailer Last edited by justy : 05-12-2008 at 10:29 AM. |
| Advertisements |
| Thread Tools | |
| Display Modes | |
