Old 05-12-2008, 07:26 PM   #1
92 sierra slx
Hard times Kustoms
92 sierra slx's Avatar
Status: Online
Member ID: 69727
dmax?
ok how big size wise in actual underhood room is a dmax compared to a small block????
Old 05-12-2008, 07:29 PM   #2
heavy-chevy
heavy-chevy's Avatar
Member ID: 71444
Re: dmax?
pretty big, with all the plumbing theres hardly any space left over under the hood. the block itself is a little larger then a big block Chevy. why do you ask, you wana do an engine swap?
01 gmc 2500 sc duramax
diablo on 120, 5" straight piped, k and n, transgo jr,boost controler, sport comp boost/pyro, bfg 285s.
Old 05-12-2008, 08:31 PM   #3
oldred95
needs to get a life
oldred95's Avatar
Member ID: 13448
Re: dmax?
Sitting on an engine stand its actually not very big. The main gerth to the bare engine is the 4 valve per cylinder heads. They're wide like a DOHC head and take up quite a bit of space. The block itself like mentioned is pretty much comparable to a big block.
1995 Silverado (see below)
1999 NBS Silverdo
Old 05-13-2008, 09:52 AM   #4
92 sierra slx
Hard times Kustoms
Status: Online
Member ID: 69727
Re: dmax?
got a crazy idea to have a bagged four door s-series blazer that lays door and instead of smallblock swap wanted to try and squeeze a dmax in
Old 05-13-2008, 11:25 AM   #5
foreman00081
IM MIKE D
foreman00081's Avatar
Member ID: 50102
Re: dmax?
would be cool to see if you could make it fit, any idea on what tranny? i doubt there would be anywhere near enough room for an allison, heck you cant even get a dmax in SC/SB becaouse the driveline is so long.
374 RWHP/679 TQ verified on superflo dyno, 9/1/07 (w/old hypertech) and thanks to Chuggs for the sig!
Old 05-13-2008, 12:17 PM   #6
FF477
FF477's Avatar
Member ID: 79400
Re: dmax?
Also remember the weight, If I remember correctly 1400lbs for the diesel.
07 2500HD 6.0 ,K&N FIPK, Hypertech,MSD
Old 05-13-2008, 12:30 PM   #7
FF477
FF477's Avatar
Member ID: 79400
Re: dmax?
My mistake, My friends Cummins diesel is really heavy. The Duramax with aluminum heads doesn't weigh much more than a BBC
Old 05-13-2008, 02:23 PM   #8
92 sierra slx
Hard times Kustoms
Status: Online
Member ID: 69727
Re: dmax?
no idea on drivetrain its just and idea for now
Old 05-13-2008, 04:16 PM   #9
heavy-chevy
Member ID: 71444
Re: dmax?
the dmax powered vans have a 4l85e i think. you could make that setup fit. it would be a tight fit for the engine, probably wouldn't have room for an inter cooler and the plumbing that goes with it. people post the dmax swap threads allot on forums and you rarely see it done, it seems like a tough job, lot of electrical crap to deal with too.
Old 05-13-2008, 04:53 PM   #10
92 sierra slx
Hard times Kustoms
Status: Online
Member ID: 69727
Re: dmax?
well its an idea and we gotta get a blazer to tear into first but research is a good start
