#1 |
Member ID: 45896
Duramax oil capacity
What is the oil capacity of the Duramax LBZ?
#2 |
IM MIKE D
Member ID: 50102
Re: Duramax oil capacity
pretty sure its the same as my LB7, 10 quarts
![]() 03 GMC 2500 HD crew duramax, 6" full traction lift. 37/13.5/20 Toyo Open Country MT's, ATS E-Power tuner, AEM intake, Stage 3 allison 452 RWHP/755 TQ verified on superflo dyno, 7/19/08 (ATS level 10) and thanks to Chuggs for the sig!
#3 |
Member ID: 45896
thanks
#4 |
needs to get a life
Member ID: 13448
Light duty trucks hold 10 quarts and the C4500,5500,6500 hold 14-16 quarts.
1995 Silverado - 4L80E swap Done
1999 NBS Silverdo - Ehhh. Its gets me where I need to go, usually.
#5 |
I have a White Eyebrow
Member ID: 56643
yep 10 and dont forget all the grease fittings under there!
Brian Threet 3-17-87 - 1-05-08
Jenna Foellmi 9-15-87 - 12-14-07 I feel you everywhere I go, I see your smile, I see your face, I hear you laughing in the rain, I Still can't believe you're gone. |
#6 | |
needs to get a life
Member ID: 13448
If you give those zerks 1-2 pumps every 25k miles or so that would be way more then enough. I don't understand why people think you have to make grease bust through the boots before its got enough grease. Grease won't evaporate, it can't go anywhere so if you grease it once that grease will still be in there. The new ones don't even grease anymore. I've all but stopped greasing customer vehicles at work because 90% of the time the boots are already buldging or they busted.
#7 | |
Member ID: 56643
i dont mean bust them dude, not an idiot. but its gotta be full. i see way to many trucks where they are completely empty. where does it go if there are no holes in it?
#8 | |
needs to get a life
Member ID: 13448
#9 | |
I'd Buy That For A Dollar
Member ID: 29834
I thought they had the same Dmax? Do they just have bigger oil pans? ![]()
#10 | |
needs to get a life
Member ID: 13448
#11 | |
Intake Gasket Specialist
Member ID: 20628
You are quite the idiot to think that 2 or 3 pumps from the factory will last the lifetime of the joint. Sounds to me like you and tools to work on these trucks is the bad combination..
Chris
'98 Chevrolet K1500 Silverado Z71 RCSB Indigo Blue - Nelson Tuned 350 Vortec/4L60E/4.10 Lockright'd 14SF/Classic II's/285 BFG All-Terrains '89 GMC C2500 Sierra RCLB - 330hp 350HO/TH400/3.73 Lockright'd 14SF/ Pictures |
#12 | |
needs to get a life
Member ID: 13448
#13 | |
IM MIKE D
Member ID: 50102
then why the he!! am i changing ball joints on my dads sable at 50k? and my 99 F150 needed them at 65k. i only replaced the ball joints on my HD at 90K cause i was putting the lift on and figured i might as well but they could have gone longer. also, the boot on one of my lowers is torn but its holding up fine still cause im able to grease it every month or so. ![]() 03 GMC 2500 HD crew duramax, 6" full traction lift. 37/13.5/20 Toyo Open Country MT's, ATS E-Power tuner, AEM intake, Stage 3 allison 452 RWHP/755 TQ verified on superflo dyno, 7/19/08 (ATS level 10) and thanks to Chuggs for the sig!
#14 | |
Driving 4x4's since 1973
Member ID: 76222
Well you have the theory down, but not the real world practicality. Sealed wheel bearings, ball joints and tie rod ends frequently fail in less than 100,000 miles, at least on GM stuff. I can't speak for other mfg's because I don't work on anything but GM, but I have replaced a lot of the aforementioned items that had between 70K and 100K on them. You are right about over greasing. Watch the boot, grease it until it starts to swell and stop. This may be one pump or several.
2006 LBZ 3500 HD
Single Rear Wheels Press 1 for English - Press 2 to learn English - Press 3 for Immigration |
#15 | |
Member ID: 20628
Precisely, I can count how many times we replaced greaseless joints on Fords/GMs at the shop I worked at. I would even go so far while the car was being serviced to use the needle on the grease gun and put some in these greaseless joints.
Chris
#16 |
Diesel Nut
Member ID: 59605
Well 10 quarts will be what your oil pan will hold, And for grease zerks. I change my oil every 8,000 miles. After I do that. I check my oil level in the differential and rear axle. Then each zerk I give it one pump of grease. I rather be a little low on grease then to much. To much grease can pry things apart like tie rods ends. So one pump is all I give them so they have something to work with. Some of the new chevy cars have no grease zerks at all. Which is nice maybe for a woman, But for me I worry if it's dry or there is something actually in there.
Real trucks don't have spark plugs! 2007 3500HD NBS Duramax 2005 2500HD Duramax sled puller 1996 1500 6.5L converted SVO/WVO 16city/22hwy 2006 arctic cat prowler 650 H1 5th wheel 34' PJ flatdeck trailer |
#17 |
Member ID: 82290
uh...lets not get carried away byes..!! we can all play in this sandpile.
Back to D,max oil capacity: Std pan is 10 Qts (litres). I ended up adding a FS2500 secondary oil filtrations set up to mine..it takes an extra litre and a hlf to fill the lines and filter. System uses a 2 uM filter cartridge. I typically do my OCI at 12,000km and the oil is in excellent shape. Takes 2-3000km to just turn dark. for what it's worth. cheers, stk
'06 LBZ CCSB SLE Blanco
TransGo Jr., Deep Ally pan, FS2500 Stdyne FM100 w/manual bypass, Banks 6Gun PDA OEM Vnt Visors, DeeZee ToolBox Sirius Sp 5, TomTom Go 720 AFE 4" Turbo Back Exhaust, AFE Air Filter, Linex - Chrome Nerfs All on HLite Mod Comm by RIM Last edited by steakman : 06-08-2008 at 08:10 PM. |
| Advertisements |
| Thread Tools | |
| Display Modes | |
