Old 06-13-2008, 08:25 AM   #1
ed1380
Member ID: 75311
diesel swap
anyone ever put a 6.6 diesel instead of a 6.0?
anyone know what the laws concerning that are? last i heard you cant put a bigger engine in than it came from the factory
thanks
Old 06-13-2008, 12:26 PM   #2
Sandracer799
Porky Mobile
Sandracer799's Avatar
Member ID: 23907
Re: diesel swap
English..... do you speak it?
2002 GMC K2500HD CCSB Dmax/Alli 13.10 @ 102.19
1995 Chevy K2500 454
1983 K20 350, Bowtie Block, Brodix heads, 14.5:1 Compression 578 RWHP
1987 K5 Blazer HT383 Crate, 4L80E
Old 06-13-2008, 03:02 PM   #3
ed1380
Member ID: 75311
Re: diesel swap
yes. also russian. how about you?
Old 06-13-2008, 04:29 PM   #4
foreman00081
IM MIKE D
foreman00081's Avatar
Member ID: 50102
Re: diesel swap
whats up with that man? other than "with" after factory id say it was a pretty perfect English sentence at least it was about 1000x better than most of the incoherant ramblings of some of these country bumpkins we got around here.
and ed, its probably been done, would most likely need to swap out the tranny that the 6.0 came with for an allison or a ZF6 manual. as far as the electronics go im not sure, of course it can be done but it might be a lot of work. you have a truck with a 6.0 that your looking to use or just an idea?
Old 06-13-2008, 04:40 PM   #5
justy
Diesel Nut
justy's Avatar
Member ID: 59605
Re: diesel swap
Trade that baby off for a truck with a 6.6 diesel in it already. It's going to cost about the same, swap or trade-in. When it comes to emissions. Engine sizes can be regulated. But being the 2500/3500 came with a 6.6 diesel as a factory option. Then it is legal to have a 6.6 in it as long as it passes emissions in your area. As for a older truck you can use any size of engine you want.
2007 3500HD NBS Duramax
Old 06-13-2008, 06:11 PM   #6
ed1380
Member ID: 75311
Re: diesel swap
i have a 05 2500hd w/ a 6.0l. if i were to put a diesel in it, it would come with the tranny, transfer case, etc. with all the wiring and stuff. ill have to ask the emmisions people about it then.
anyone know if the frame and engine mounts are the same?
Old 06-13-2008, 08:35 PM   #7
justy
Diesel Nut
justy's Avatar
Member ID: 59605
Re: diesel swap
If it's a HD, yup. diesel and gas have identical frames. Only difference is transmission and a diesel engine. There used to be the 8.1 gas with the Allison transmission also. The difference was torque converter stall speed. If your converted you 6.0 gas to a diesel. You would need computer, engine, transmission, and maybe wire harness. I don't know for sure because I never done this swap. I would think you would need different engine mounts as well.
Old 06-23-2008, 04:18 PM   #8
BuilditBig
BuilditBig's Avatar
Member ID: 91258
Re: diesel swap
Among that you would also need a completely new fuel system and fuel tank
1994 Z71 Ext Cab, Bushwacker Flares, K & N, Headers, Magnaflow exhaust, Roll Bar w/ Dick Cepeck Lights, Nerf Bars, Pro Comp es 9000, 3" PA, Torsion Keys & 2" blocks, gonne be 6" pro comp soon.(pics coming when all the work is done)
