Old 10-14-2009, 02:24 PM   #1
4Bt in an 85 1/2 ton.
I already posted this in the classic section before I noticed the diesel section. After looking at the other 4Bt swap, I decided to post here also. Mods, remove one if it needs it.
This is my second 4Bt swap. I had this engine in my son's jeep and he rolled it so we decided to put it in a pickup and he loves this body style.
Here is a photo of the truck and the 4Bt and the jeep it used to be in.
When I die, I want to go quietly in my sleep, like my Grandpa;.......not screeming in terror like his passengers.
rrbgtt is offline
Old 10-14-2009, 07:28 PM   #2
Re: 4Bt in an 85 K1500
I feel like I saw a jeep just like that with the 4BT in Diesel Power awhile back. Sorry to here about the jeep, but sick to hear it's pushin a chevy! Show me more pics!
tank454 is offline
Old 10-14-2009, 07:53 PM   #3
That was our jeep in Diesel Power. We spent two years building it and it took my son, Garrett about 2 seconds to total it, but now we have another project and I think he'll like the truck better. It will be a much better daily driver with A/C and overdrive. We haven't started the Chevy swap yet, but if you want to see the jeep build thread, here is the link.
http://myjeepclub.com/showthread.php?t=828
rrbgtt is offline
Old 10-14-2009, 09:05 PM   #4
gr8twhite's Avatar
OD?
What are you plannig to use for a trans?
gr8twhite is offline
Old 10-15-2009, 04:36 AM   #5
Originally Posted by gr8twhite View Post
OD?
We are going to use a 4L80E with a stand alone controller. I don't believe the 700R4 that's in the truck would ever hold up to the torque.
rrbgtt is offline
Old 10-15-2009, 04:22 PM   #6
crossy's son's Avatar
, very nice
Ve pumped i'm guessing?? Thats gonna be fun
91 RCSB|350|5 speed|3.42 G80|400k miles+|stock...15.67 @84
^ 89k 350,tbimods,Spacers,headers,Southbend clutch,AFPR...soon to be dropped in.:)
Dad's-87 SWB 2wd|305tbi
stuff-4 cummins powered dodge rams
& 81 C10 swb 13.54-1/4 ET,5/8 drop
94 K1500 ECSB 4x4,5.0L,4L60E,3.73's,Magnaflow
crossy's son is offline
Old 10-15-2009, 06:21 PM   #7
Originally Posted by crossy's son View Post
, very nice
Yeah, it's a 14mm pump turned up to just shy of runaway with a Denny T stage II fuel pin, no throttle stop, and a3200rpm spring. We have an HY35 with a 9cm exhaust housing, cut down 5.9 exhaust manifold and 100hp injectors. It has heavier valve springs and a few other mods. It was mean in the Jeep and we are anxious to see what the truck performs like with it.
rrbgtt is offline
Old 10-15-2009, 06:24 PM   #8
Urban Cowboi
rebelbowtie's Avatar
i love it. 4BT swaps are the ****. i also love whenever i see a member post pictures from florida i have to do a double take and check their location. welcome from west palm.
Thanks xZoomerZx
rebelbowtie is offline
Old 10-15-2009, 06:32 PM   #9
Awesome! Is it a rocken-tech 14mm pump or KTA pump??
And that DennyT pin is the $hit ain't it??? we have one in all our 1st gen dodges w/the VE !!! best 100 bucks spent, and the gov. spring is so awesome too.
Old 10-15-2009, 07:15 PM   #10
81chevyc2500's Avatar
thats going to tbe sick i want to see the build thread when you start it
86 k2500 blown motor getting 14 bolt ff with locker and d60 up front 6inch bds suspension and boggers
86 blazer 4 inch lift getting boggers soon and a winch
86 3/4 ton 2wd work truck 4spd stock
81chevyc2500 is offline
Old 10-16-2009, 07:21 AM   #11
RAMZ TRK
Why 4bt and not the old diesels that come in Chevy trucks?
2004 GMC Seirra ECSB 4X4 5.3 AUTO
Originally Posted by someotherguy View Post
It's always easier to ask forgiveness, than ask permission!
Richard
fastlt1 is offline
Old 10-16-2009, 07:30 AM   #12
Two reasons. Horsepower and Torque.
rrbgtt is offline
Old 10-16-2009, 08:44 AM   #13
RAMZ TRK
What kind of hp and torque do they make stock and turned up? Thanks.
Richard
fastlt1 is offline
Old 10-16-2009, 09:05 AM   #14
Stock, they are 105hp and 275 tq. This is way below their potential (just like the 5.9's)
Before we added the 100hp injectors(we had 50hp injectors at the time) and took out the throttle stop, ours (in the jeep, with a Th400, 14 bolt rear, and 40" tires) made 207hp and 475lb/ft of torque to the rear wheels. The hp was @ 2450rpm and the torque was at 1900rpms. After the injectors and additional timing tweeking, we were over 40lbs of boost with the new injectors. My guess is we are around 280hp at the flywheel now.
And the compound turbo set is in the works.
rrbgtt is offline
Old 10-16-2009, 01:51 PM   #15
Jerk of all Trades
Quyonmob's Avatar
The old 6.2L is more for swapping out than it is for swapping in. It's a bit of a slug, and lacks any major potential.
92 k1500, 305TBI; Ultimate TBI mods, K&N, 700R4; B&M shift kit, Posi-lok, 32x11.50 BFG A/T's, 15x8 AR767's. Barely cranked and blocked.
Quyonmob is offline
Old 10-16-2009, 01:52 PM   #16
Urban Cowboi
i still have a soft spot for them. i want a CUCV for wheeling.
Thanks xZoomerZx
Old 10-16-2009, 01:56 PM   #17
They wouldn't happen to be POD injectors are they?? I think they're rated at 100hp or something... 4x.014 tip size.
And you didn't answer my question about the 14mm pump head/rotor? whos it made by ?
Old 10-16-2009, 07:30 PM   #18
The POD's are 50hp injectors. We had those first. The 100hp injectors were custom made by Tennesee Diesel Conversions.
I don't know which 14mm head I have. I took the injector pump off when it started leaking and took it to be rebuilt. Accurate Diesel Injection in Orlando did the rebuild. He called me and told me he had a 14mm head and did I want it and I said yes.
rrbgtt is offline
Old 10-16-2009, 09:51 PM   #19
how hard is it to swap in one of these motors in to ur truck
where can you buy them and how much do they cost i have a brand new just rebuilt sm465 sitting in my garage i want a diesel they seem alot cooler than gas engines but if i wanted to do the swap what would i need and what would have to be changed out
Old 10-16-2009, 10:13 PM   #20
Oh hai
Manbearpig's Avatar
I'd love to have a 4BT in my K5
****, I'd jizzinmypants with a 6BT.
2004 Sierra SLT Z71 /5.3/Hooker Aerochamber/3.73's
1984 K5 Blazer-Silverado /5.8/none/3.73's/Quadrafail
Manbearpig is offline
