Originally Posted by Levi18
Whatever you do, don't use ether without turning it over a couple times.
Should be "don't use ether, ever" Ether (starting fluid) will toast your glow plugs. If you need something to help starting, use WD-40.
Other than that, do some of the same things as with a gas engine. Maybe pull the glow plugs to allow for easier cranking. Perhaps pour a little oil into each cylinder to lube up the sides, ect. Clean the tank, change the oil and filter and fuel filter.
I am going to plug the resources I use:
www.thedieselpage.com, and I have used Kennedy Diesel (kennedydiesel.com) for both parts and information resource, but I have used Heath as well for some things.
