Re: Very loud engine noise
How loud of a "chattering noise"? Does it only do when it is cold? only warm? All the time?
More smoke and loss of power is normally due to a failing wastegate system. But the only way your wastegate system would fail is if the spring failed, which doesn't happen that often.
How many miles do you have on the injectors? If you think it is injectors causing your issue you can either take them out and get them tested, or just replace them as they don't cost too much if you have a little extra money to spend.
1995 K2500 Silverado
6.5L Turbo Diesel
