Old 03-10-2008, 05:08 PM   #201
D-BoB'91
HID Retrofitted
D-BoB'91's Avatar
Member ID: 29023
Originally Posted by silverado179
I have TYC projector headlights in my 01 and unlike all the other projector lights I've seen there is no "warning do not use HID in this headlight" sticker and I took it apart one time to see how to cahnge the bulb and its a really small bulb, nothing like factory lights. I was told its the same as the H3. I've also seen headlights similar to mine with the different bulb and it has a cutoff and that "color mod" and all he did was add the ballast and the bulb. his lights are bright and are aimed right making a straight line all the way across like my regular bulbs do now so I'm thinking I might can use these projectors. what do you think? I'm not trying to get out cheap or anything but I don't want to go cutting things and switching everything out if I don't need to.
It's worth a shot.....if they don't work out, THEN would be the time to cut out the old projectors.
Old 03-10-2008, 06:47 PM   #202
akjay907
98 K1500
akjay907's Avatar
Member ID: 84724
hey dbob i know its not part of your thread but i got a 98 single cab shortbed like yours. what do you use for your subs? cuz im trying to find something good that will hit hard and sound good...
gallons per mile...
Old 03-10-2008, 06:50 PM   #203
D-BoB'91
HID Retrofitted
D-BoB'91's Avatar
Member ID: 29023
It's in my sig
Old 03-10-2008, 07:51 PM   #204
Crazed179
Harley
Crazed179's Avatar
Member ID: 70676
well I'll give it a shot and let you know if it works..now I just gotta find the other stuff that'll work with what I have now. I like the way you did yours though so I might do it anyways for something to do, even though I need to get some paint...nice write-up btw
Old 03-27-2008, 06:44 PM   #205
Trolin
Trolin's Avatar
Member ID: 42462
I would think you could use the tyc projectors. I have a set also and mine use an H1 (i just had to replace one). I like them because they cutoff real nice like the pics that were posted early in this thread. Mine don't have clear glass though its kind of opaque. I was thinking about throwing a cheap kit in there just to see what it looks like. Any ideas? I know I can't spend this much time and money to do it the right way.
2001 Z71 ecsb -Sunset Orange- Wait4Me Tune, flowmaster 40, K&N cai, TYC headlights, billet grille, KC's, Chrome American Racing Fuel's 16x8's 285/75 Toyo AT, RMX monotubes, Rear Airbags, White gauges W/3D bezel, tinted tails
Old 03-27-2008, 09:17 PM   #206
Crazed179
Harley
Crazed179's Avatar
Member ID: 70676
I'm the same as you on that one. I think the lights I have in mine now are the same as yours..with like a chrome peice around the projector with holes all in it. they do have a nice cut off, I was thinking about getting that battery thing and changing the bulbs out. too many other projects ahead of that one though so let me know how it works if you try it
Originally Posted by sweet tea man
It really sucks getting caulk all in your face
BUILD THREAD --- http://www.fullsizechevy.com/forums/...1-ext-cab.html
www.myspace.com/silverado179
Old 03-27-2008, 10:32 PM   #207
Trolin
Trolin's Avatar
Member ID: 42462
Yeah I will repost when I get around to completing it. I think I might try a cheaper route that the original poster here. I can't afford to spend hundreds on this mod. I have already spent a fortune on this truck and with two car payments and a baby due any day I have to slow down on the spending.
Old 05-02-2008, 12:35 PM   #208
xAustin
knows nothing, needs help
xAustin's Avatar
Member ID: 72054
i feel like a tard for get getting the $12 ebay HIDs now. lol
02 5.3 silverado
Old 05-02-2008, 03:09 PM   #209
D-BoB'91
HID Retrofitted
D-BoB'91's Avatar
Member ID: 29023
Old 05-02-2008, 03:27 PM   #210
xAustin
xAustin's Avatar
Member ID: 72054
this still do make a difference tbh though. i pointed them down a tad so they arent blinding to everyone so they still are better then the regular bulbs.
02 5.3 silverado
Old 05-14-2008, 11:04 PM   #211
hekg
Member ID: 26579
Great write-up D-bob ... You da man!
Old 05-15-2008, 06:32 AM   #212
D-BoB'91
HID Retrofitted
D-BoB'91's Avatar
Member ID: 29023
Thanks man, I love 'em
Old 05-22-2008, 09:36 PM   #213
Quest!1
Member ID: 71002
good job on hid info
FS: XENTEC HID KIT $120 shipped P.M me for more info
1999 4D Tahoe 5.7L
Old 05-23-2008, 09:02 AM   #214
D-BoB'91
HID Retrofitted
D-BoB'91's Avatar
Member ID: 29023
Thanks, I appreciate it
Old 05-28-2008, 01:51 PM   #215
neevnav
The Flying Dutchman
neevnav's Avatar
Status: Online
Member ID: 61087
Alright, so I've finally put some more work into my retro, and I'm getting so close, but I've got two quick questions.
First, I'm doing the build my own mounting brackets, and I was wondering, on yours, it looks like you bolted the angle iron to the housings on the top. On the HID planet article, he used JB weld. I'd rather bolt them, if that was the case on yours.
And two, I'm almost finished my wiring harness, but I'm not sure what to do with the ground from the female 9006 plug. Should I just ground it?
Thanks man, if all goes well I should finish this tomorrow or Friday!
Mike
1994 K1500 350 491,000 original KMs
K&N Open Element, MSD 6A, Cobalt SS E-fans, BFG A/Ts, Cat-back duals
Originally Posted by chriskelley2003
hell the idiots around here make posts look like rocket scientists
Old 05-28-2008, 02:12 PM   #216
D-BoB'91
HID Retrofitted
D-BoB'91's Avatar
Member ID: 29023
Mike
Good to hear
On my mounting bracket I had to use both...the corner over the projector is JB welded and the center section behind the high beam is bolted on.
My advice is to make sure you sand, scuff, scrape, or do whatever you can to get rid of the smooth surface, the JB weld will not stick to it!
On the wiring harness, if I remember correctly, both ends go to the relay. Or maybe I grounded it with the rest of the grounds in the wiring harness?
Maybe this will help...
Yeah, looks like ground goes to 86 and power to 85, its been awhile though so you should double check
Old 05-28-2008, 04:15 PM   #217
neevnav
The Flying Dutchman
neevnav's Avatar
Status: Online
Member ID: 61087
Gotcha. Thanks man. Wiring harness is done, on to mounting and aiming tomorrow!
Old 05-29-2008, 01:35 PM   #218
atv_freak
Supporting Member
atv_freak's Avatar
Member ID: 21385
Can't wait to see it!
Old 05-30-2008, 01:33 PM   #219
neevnav
The Flying Dutchman
neevnav's Avatar
Status: Online
Member ID: 61087
The angle pieces you're using, are they 2x2? Cause I just mock measured mine out, and realized it was too small, and it was only 1.25 x 1.25. So I think I'm going to have to go and get some 2x2 tomorrow.
