#161 |
www.subsonickustomz.com
Member ID: 47758
well myne sure do...how is your relay wired?
#162 | |
The Flying Dutchman
Member ID: 61087
Relay to battery, ground to ground, high to pole 85 or 86 (the on switch) low to 87. My lows don't flicker at all when I switch, highs just come on.
1994 K1500 350 491,000 original KMs
K&N Open Element, MSD 6A, Cobalt SS E-fans, BFG A/Ts, Cat-back duals Quote:
#163 |
Member ID: 47758
weird...mynes the same way and they turn off for a split second...oh wells
#164 | |
Member ID: 73054
Something doesn't make sense because pin #87 is switched so how can the LB stay on when switched to HB? Is there something else in your harness that you forgot or am I missing something here?
#165 |
thanks d-bob 91...what do you think of the 9006 bulb in the tsx projector??...should I use this or should I buy some d2s with ballast?
#166 | |
The Flying Dutchman
Member ID: 61087
DRLs are disabled. Pulled that fuse years ago. I don't think I forgot anything, I'll double check tomrorow in daylight.
#167 | |
Member ID: 73054
Did you make the harness? Is there a diode or something in there to keep the LB voltage from flowing back when HB are flicked on?
#168 | |
The Flying Dutchman
Member ID: 61087
I actually purchased the harness from Mrtaillight.com and it came all wired together in looms, so it's possible they put a diode in.
#169 |
Member ID: 73054
Thanks for the info, I sent him an E-mail to ask if his kit works with DRL's. For $12.99 it's not worth me making, parts alone are probably close to that up here.
#170 | |
The Flying Dutchman
Member ID: 61087
The only thing he gets us on is shipping, but yeah, it is easier in the long run.
#171 |
Member ID: 47758
I see no real need for ever using my highbeams so its not really a big deal anyway...my HIDs drown out the dull halogen highbeam anyhow.
#172 | |
Member ID: 73054
#173 | |
The Flying Dutchman
Member ID: 61087
I think it was like $20.
#174 | |
HID Retrofitted
Member ID: 29023
#175 |
Member ID: 47758
true...i dont even bother with my high beams anymore...
#176 |
Supporting Member
Member ID: 21385
I haven't wanted to use the high beams yet. Last night I was driving the family astro van... wow do halogens suck!
#177 | |
HID Retrofitted
Member ID: 29023
The wife's Honda has silverstars and even they suck compared to HID's. ![]() |
#178 |
twentyonenineninetyfive
Member ID: 9827
you did an awesome job with those hids and did your homework, but i put hids on my truck over three years ago (8000K) and mine look just as good if not better and i just put a lit in specifically made for a composite type headlight...
garrett
#179 | |
The Flying Dutchman
Member ID: 61087
What do you mean made specifically for a composite headlight?
#180 |
HUMMER
I believe he meant the word "kit" not lit. Did you do a HID reflector swap into the halogen housing? If not I hope that housing hasn't turned into a glare monster for oncoming traffic.
| Advertisements |
| Thread Tools | |
| Display Modes | |
