Old 03-17-2008, 06:02 PM   #1
JB
2008 NNBS
JB's Avatar
How too clear NNBS GMT900 07-08 Silverado Headlights
How too remove NNBS GMT900 07-08 Silverado Headlights
This may not be the only way to clear your lights, some may like the oven method but it didnt work for me and actually melted a light. Therefore, I found this to be the best method for me, and it has worked well for myself and others.
DISCLAIMER >>> I am in no way responsible for anyone that trys this method and scews up their lights...so only do this if your confident....we all have different skill levels that were comfortable with.
The only tools I used is an air cut-off tool with a 3" X 1/16" thick disc, an exacto knife to clean up the edges later, and a screwdriver to pry off the amber sections. The other tools were used for removeal of the light (10mm).
I found it easiest to place the headlight in a box to hold it into position while cutting. You will also need to remove the foam from one side, but take notice of its location because you will reinstall it after your finished.
I like to start with this side, because it has the thinest section as to where to cut and a molded bracket that is kinda in the way.
Just position the light in the box and start cutting approx where I did here, working your way from one end to the next. Caution...do not cut too deep or you will cut into the chrome plastic thats underneath. I just score the plastic with the disc, then slowly work myself down till I cut thru and then stop and move on a few inches. This takes time so be patient.
Once you have that side done, flip the light and do the next side beginning at the corner where you left off.
Then the nest side
Then the next side
Once all sides have been cut, remove the lense from the housing assembly.
Next is to remove the amber lense. The amber lense has two clips at the chrome center and two that are hooked under and glued to the base. The lower two will need the tabs cuttoff but be careful not to damage the chrome or cut too deep.
Next step is to clean the edges. The little pieces just pull off and/or will need slight trimming with the exacto knife.
Take your time cleaning these edges, just like anything else...preparation is everything.
Next you need to blow off any remaining plastic dust/particles etc of both the housing and the lense. Then you need to wipe off any and all fingerprints/residue from both pieces.
I used GE 100% Silicone Glue from Home depot. Its clear and cost about $3.50 a tube which is plently for both lights.
Place a small bead along the housing base cut edge, making sure you dont get too much or it will ooze inside and be visible. After the small bead is apllied, place the lense on top and align the corners. You may need to place something heavy on top while it dries. After 30-60min, place a nice thick bead on the outside to seal out moisture. You can smooth this with your finger so it looks good. This is hidden behind the grille/fender/bumper...only the top can be seen with the hood open if you know what your looking for.
Congrats....you now have a factory cleared headlight
2008 Chevy Silverado 1500 RCSB LT1
JB is offline
Old 03-17-2008, 06:11 PM   #2
S/C Z71
Guest
Posts: n/a
Re: How too clear NNBS GMT900 07-08 Silverado Headlights
Congrats! Your headlight assemblies are no longer legal.
Old 03-17-2008, 06:13 PM   #3
churd69's Avatar
that's hott!!!! nice work, think i might have to search for the thread on how to do that one mine, but i think the nnbs look 100xs better that way!
churd69 is offline
Old 03-17-2008, 06:18 PM   #4
Forum Leader
oneloudz71's Avatar
Great write up JB!
Like to photoshop? Check this out...http://www.fullsizechevy.com/forums/...k-contest.html
oneloudz71 is offline
Old 03-17-2008, 06:54 PM   #5
I have been waiting on a full write up on this. I just haven't been able to bring myself to cut the headlights apart on a brand new truck. I know I can do it and not screw it up, I just need to find the time to do it when I can take my time and make it perfect.
2009 Silverado Ext. Cab Vortec Max 4x4
2.5" Total Performance Leveling kit, 5% Tint
Mods to come(some day): 8" Suspension & 35x14.5 Iroks, 4.88 Yukons, Detroit True Trac, LTs and Magnaflow muffler, Blackbear Tune
jmcgriff19 is offline
Old 03-17-2008, 08:12 PM   #6
JB
2008 NNBS
JB's Avatar
I felt the same way...then one day I just went out and did it. It takes me about an hour to complete, but I take my time on the clean-up of the cut edges.
btw....I used 3157/4157A-ST sylvania silverstars for the bulbs. They were $9.99/pair at pep-boys.
JB is offline
Old 03-17-2008, 09:28 PM   #7
The Flying Dutchman
neevnav's Avatar
Looks awesome! Nice job!
1994 K1500 350
K&N Open Element, MSD 6A, Cobalt SS E-fans, BFG A/Ts, Cat-back duals, TSX HID retrofit
Originally Posted by Jim
I'm out of state withno Internet. I had to fix the forum with my iPhone. Sorry guys
neevnav is offline
Old 03-17-2008, 09:40 PM   #8
1
REG CAB 07 is offline
Old 03-19-2008, 03:57 AM   #9
No more F'n Bailouts!
Toolman's Avatar
Both look good. Any photos of the black ones installed?
You get what you pay for, Nothing in life is free!
Toolman is offline
Old 03-19-2008, 06:27 AM   #10
JB
2008 NNBS
JB's Avatar
http://www.fullsizechevy.com/forums/...some-pics.html
JB is offline
Old 03-19-2008, 09:00 AM   #11
S/C Z71
Guest
Posts: n/a
Originally Posted by REG CAB 07
Much better.
Old 03-19-2008, 11:00 AM   #12
House on the HILL!
CKTA's Avatar
Nice write-up. I think the black or body color looks alot better. Those lights are HUGE and painting them to match makes the truck look alot better IMHO.
2010 Carlisle All Truck Nats info..
http://www.fullsizechevy.com/forums/...aug-6-8th.html
CKTA is offline
Old 03-22-2008, 12:17 AM   #13
Where's My Beer??
BigD_htl's Avatar
any moisture??
BigD_htl is offline
Old 03-22-2008, 12:33 AM   #14
S/C Z71
Guest
Posts: n/a
This made a sticky?
Old 03-22-2008, 12:58 AM   #15
Originally Posted by BigD_htl
any moisture??
I have never had a problem, This isn't the first set of lights I have opened up so I knew to seal them up really well.
Old 03-25-2008, 06:58 AM   #16
04 Black SS
schreier's Avatar
Anybody know if you can do this with 07 silv classic headlights? I would think that you could clear them the same way, but has anybody painted theirs?
schreier is offline
Old 03-26-2008, 09:59 PM   #17
How would this be considered illegal?
LongHorn07 is offline
Old 03-27-2008, 10:27 AM   #18
JB
2008 NNBS
JB's Avatar
Just do it....I have had clears on all my trucks and never had a problem at inspection or from the cops.
JB is offline
Old 03-27-2008, 11:32 AM   #19
Would this look good on a silver birch truck?
I'm not that confident in doing it myself, but would get someone else too if it looks good.
Old 04-01-2008, 03:18 PM   #20
Rescuehoundemtd's Avatar
Anyone have any experience putting the diamond cut clear euro lense kit on the front of a 98 Zee. I just order the kit on ebay Headlights, turns, markers. I also bought 8500K xenon/krypton bulbs. I know I have seen a lot of trucks on here that have the clear lenses. How do the headlights come out? Thanks.
RescuehoundEMTD
98 Chevy Z71,5.0,SB,Catback Flowmasters
90 GMC Vortec 4.3 LB
Rescuehoundemtd is offline
