Old 05-09-2008, 08:11 PM   #1
1980scottsdale
Member ID: 66996
Wheel Spacer on 97
After I put my 265 BFGs on 16X8 eagle rims 4.25 BS on my 97 Gmc, the back tires seem a little tucked behind the fender. The front looks fine, but I would like the back to stick out farther. I am not changing my tires nor rims.
What do you guys think about wheel spacers? I am looking at some on ebay that are cnc machined aluminum and have grade 8 carbon steel studs and are 1.5 inches thick. Do you think this is a good idea or what? Any suggestions welcome. Thanks
1980 2wd scottsdale 350 sbc dual flowmasters, hooker headers, kn air filter, 268 comp cam, flat top pistons, holly carb, edelbrock intake
1997 GMC 2500 5.7 47000 miles true dual flowmaster exhaust
Old 05-09-2008, 08:14 PM   #2
Big Orange 83
To LA'GIT to QUIT!!!
Big Orange 83's Avatar
Member ID: 86248
Re: Wheel Spacer on 97
i got 1/4 inch spacers on mine on the front and I can really tell it, i couldnt even just imagine a 1 1/2.. but its all what looks good to you
Old 05-09-2008, 08:38 PM   #3
1980scottsdale
Member ID: 66996
My tires seem to be way back under the fender. The truck is a 3/4 ton so it has fender flares.
Old 05-09-2008, 09:22 PM   #4
1980scottsdale
Member ID: 66996
bump
Old 05-09-2008, 09:47 PM   #5
silverbell06
silverbell06's Avatar
Member ID: 88229
I've run wheel spacers on my 02 Explorer for over a year with no problems, even towed a trailer w/ quad and dirtbikes. Just gotta check em every so often to make sure they don't loosen. Loctite helps on the inner lugs. I have em on my Silverado also. If you are going to tow heavy or do alot of offroading then I would shy away from em. More things to break. But for daily driver, no problem.
Old 06-24-2008, 07:42 PM   #6
kevinv
Member ID: 25
I need a 5/8" spacer or so... for my Blazer... same problem as above... anyone know where to get a good quality one?
KV
kv@blaze-tech.com
