Old 06-22-2008, 08:56 PM   #1
giilby
Member ID: 91303
smokin tail lights
does anyone have any steps on smokin tail lights? they told me to just use spray paint like for vinyl and coating them..will that work?
Old 06-22-2008, 10:31 PM   #2
Trolin
GONE FISHIN'
Trolin's Avatar
Member ID: 42462
Re: smokin tail lights
There are a lot of threads on this topic in the exterior section. I have posted a couple myself.
This is the way I did mine:
1.Prep area with 300 grit sand paper
2.Cleaned off light, and I masked off reverse light so I can see when I back up.
3.Used adhesion promoter/clear primer duplicolor brand I believe
4.applied light coats of black from a distance to acheive the desired look.
5.applied duplicolor clear acrylic laquer.
6.after 48hrs I used a light rubbing compound and wax. They are holding up really well, and still look like I just did them yesterday.
2001 Z71 ecsb -Sunset Orange-
2002 Tahoe
Old 06-23-2008, 10:26 PM   #3
giilby
Member ID: 91303
thanks imma try that when i get a chance.
Old 06-23-2008, 10:39 PM   #4
CamaroGuy87132
Premium Member #21
Not Anymore
Member ID: 31507
Steps in order
1. Steel wool
2. All purpose cleaner
3. Thin light coats
4. Wait a few minutes in between coats
5. Wait 15 minutes and clear coat.
USE NITESHADES! Or just send them to me and I'll do it for 15 bucks haha.
"And a word to the wise when the fire dies,
You think it's over but it's just begun"
Old 06-24-2008, 05:33 AM   #5
stockchevy1983
98 yukon and 98 s10 p/u
stockchevy1983's Avatar
Member ID: 73514
this is the site i read before i tinted my tails
http://www.350z-tech.com/zwiki/Tutor...ing_Taillights
ADDICTIVE ENDEAVORS
98 yukon - 2wd, 4door, vortec 5.7, cold air intake, straight 3 inch dumped, 6k hid, 15inch soundstream pcw-15 sub with alpine mono amp.
Old 06-24-2008, 11:43 AM   #6
91blkstpsd
Slow Truck
91blkstpsd's Avatar
Member ID: 22825
Have done several sets like this. Check my build threads for pics.
1. wetsand with 400
2. clean and wipe with tack cloth
3. mix black basecoat and activator
4. mix clearcoat and hardener
5. pour black into clear at about a 1:10 ratio and mix
6. spray as many coats as desired tint
7. Stand back and enjoy!
http://www.myspace.com/newdrewman
'06 CC Z71, RC leveling kit
'91RCSB:LT1 & 4L60E swap,LT4 cam,1.6RR,52mm BBK TB, ceramic headers,MSD ignition,8mm wires,Built trans,TransGo SK,TCI stall,Ultralite Gauges,leather+suede,billet,4-6 drop, 20"s
Old 06-24-2008, 08:09 PM   #7
Silv3rado Own3r
Rolling on DUECE 2'S!
Silv3rado Own3r's Avatar
Member ID: 65541
do you need to use adhesion promotor with nite shades?
SUB FOR SALE JL10W6 NEVER BEEN USED
http://cgi.ebay.com/ws/eBayISAPI.dll...m=140257158021
