Old 11-02-2009, 08:52 PM   #1
tire width?
what determines how wide of tires I can out on a wheel? sorry have no clue about this stuff.
98w/t is offline
Old 11-02-2009, 09:06 PM   #2
ChrisJ8510's Avatar
Re: tire width?
Depending on how wide your wheel is depends oh tire width, u can only run so wide of a tire on a certain sized wheel, what setup are u trying to achive and can tell u if its to wide for the rim
1989 K1500, 3 inch body lift, 33x12.50 BFG KM2, True Duals(no cats), Glasspacks.
1987 Suzuki Samurai, spoa and 31's. And will go anywhere
ChrisJ8510 is offline
Old 11-02-2009, 09:09 PM   #3
has been "had"
bhookxen's Avatar
Re: tire width?
usually you can look up the tire's specs online to see what that brand "recommends". but you can usually fudge quite a bit either way.
- i'm new
<-thanks again, xZoomerZx
96' burb - 6-inch RC, 4.56's, 35's, detroit, SYE, realift, flow 50's, w4m, 06' 17's, other stuff
98' silvy - z71, 285's, flow 50's, 1" block, some crank, blackbear
bhookxen is offline
Old 11-02-2009, 09:29 PM   #4
94_c/1500's Avatar
Re: tire width?
Try to keep it within about 4 inches. If you are running a really wide tire, such as a 15.50 or something bigger, I might go within 3-6 inches.
Post the size you are wanting to run and we can help you out.
1994 GMC Sierra, 1982 Jeep Scrambler, 1975 Jeep J10
Drive a pickup truck, trustin' God and luck
http://www.fullsizechevy.com/forums/...my-trucks.html
94_c/1500 is offline
Old 11-03-2009, 09:15 AM   #5
HEROES LIVE FOREVER
WildChevys's Avatar
Re: tire width?
what size are you looking at?
James
2008 Chevy Silverado LTZ Vortec Max
Superlift/XD/Toyo/EFI Live/K&N/Vortex/Pioneer/Bose/Alpine/and more
WildChevys is offline
Old 11-03-2009, 09:23 AM   #6
Forum Leader
oneloudz71's Avatar
Re: tire width?
What determines it? Well, there are a few different answers to that.
1. A engineer at the tire company.
2. The consideration of how wide or narrow a certain size tire can be with a certain size wheel and be considered safe as far as not posing a threat of coming off the bead.
3. A person at the tire shop and there level of experience and if they can squeeze a wide tire onto a narrow rim.
Now, help us out. Ask what you really meant to ask and tell us sizes that you were thinking.
Like to photoshop? Check this out...http://www.fullsizechevy.com/forums/...k-contest.html
oneloudz71 is offline
Old 11-03-2009, 10:21 AM   #7
Flawed Behavior
someotherguy's Avatar
Re: tire width?
X2 on that. I always look up the tire specs on www.tirerack.com when I'm curious, I use that feature a lot. Just go to the site, do a lookup by size, and then pick a tire from the results - click "specs" and it'll be at the top of the page. What's handy is all the other sizes available in that model/brand are shown below so you can see what might be a better fit.
Richard
94 C2500LD, 94 3500HD, 98 C3500, 48 Harley chopper
Free beer tomorrow
someotherguy is offline
Old 11-03-2009, 11:24 AM   #8
Forum Leader
oneloudz71's Avatar
Re: tire width?
While that is true that all the manufactures give specs and different tire sites will list these specs, like someone said before you can run tires wider and narrower than what the manufacture says you can.
Old 11-03-2009, 11:42 AM   #9
Flawed Behavior
Re: tire width?
Yes, which is why I agreed with the quote I posted saying you can fudge a bit either way.
Richard
Free beer tomorrow
Old 11-03-2009, 11:42 AM   #10
phantom member
zebra86's Avatar
Re: tire width?
aspect ratio also is a big factor. you ain't gonna be able to run 275/55r20s on a 6.5" wide wheel like you could with 265/75r16s
the height of the sidewall helps determine how much flexibility you have on the width
zebra86 is offline
Old 11-03-2009, 04:14 PM   #11
Re: tire width?
I just want to know how wide I can go with the stock wheel on a 98 chevy w/t 1500 5 lug. i think its 235/75/15 cant remember
98w/t is offline
Old 11-03-2009, 04:17 PM   #12
Forum Leader
oneloudz71's Avatar
Re: tire width?
Stock wheel=7.5-8" wide. Others have run 12.5's with no problem.
Old 11-03-2009, 04:20 PM   #13
Re: tire width?
so what tire size should I run. I hate all that rubber and such a thin wheel.
98w/t is offline
Old 11-03-2009, 04:22 PM   #14
Forum Leader
oneloudz71's Avatar
Re: tire width?
What are you trying to accomplish? A taller tire on stock wheels at stock height? A wider tire on stock wheels at stock height? Or A taller and wider tire on stock wheels at stock height?
Old 11-03-2009, 04:23 PM   #15
Re: tire width?
98w/t is offline
Old 11-03-2009, 04:24 PM   #16
Forum Leader
oneloudz71's Avatar
Re: tire width?
Get some 33x12.5x15's and call it a day!
Old 11-03-2009, 04:24 PM   #17
Forum Leader
oneloudz71's Avatar
Re: tire width?
That would be wider and taller.
Old 11-03-2009, 04:25 PM   #18
Forum Leader
oneloudz71's Avatar
Re: tire width?
What size do you have now? Lets start there so we can tell you what wider would be.
Old 11-03-2009, 04:27 PM   #19
Re: tire width?
235/75/15 as of now.
98w/t is offline
Old 11-03-2009, 04:29 PM   #20
Forum Leader
oneloudz71's Avatar
Re: tire width?
Alright, that equates out to a 28.75 tall by 9.25 wide tire. Go get some 31x10.5's and you are a little taller and a little wider. Do some cranking and get some 33x12.5's and you will have alot nicer stance.
