Old 11-05-2009, 12:05 AM   #1
Arnold355's Avatar
finally blacked out bowtie
Came back to my dorm after class today and got bored so my buddy and me decided to black my bowtie...keep in mind first time to do this
Arnold355 is offline
Old 11-05-2009, 12:18 AM   #2
smokinsilverado's Avatar
Re: finally blacked out bowtie
the bowtie looks good, now your next piece of homework is to colormatch the grill.
05 Silverado 5.3, Whipple , Nelson tune, JBA Shorties, 80mm BBK Throttle Body, 6" Tuff Country lift, 325/65/18 Toyo ATs, Avic D3 with 2 small 8's
smokinsilverado is offline
Old 11-05-2009, 12:21 AM   #3
Arnold355's Avatar
yep im going to order a grille and then paint the edges black
Old 11-05-2009, 12:35 AM   #4
HEROES LIVE FOREVER
WildChevys's Avatar
nice job
James
2008 Chevy Silverado LTZ Vortec Max
Superlift/XD/Toyo/EFI Live/K&N/Vortex/Pioneer/Bose/Alpine/and more
WildChevys is offline
Old 11-05-2009, 11:12 AM   #5
1CLNY2K's Avatar
Looks good. Could have saved some note taking paper by just removing the emblem itself.
2000 ECSB, 4.8 5 speed NV3500, man t-case,tru-trac, W4M tune. 3/4 drop brought to you by Belltech, 285/55/18 coopers on matte black titans. Maybe working on a 4/6 drop
1CLNY2K is offline
Old 11-05-2009, 12:04 PM   #6
DMANbluesfreak's Avatar
Question, I'm in the process of painting mine now. Did you wet-sand at all in between coats? Did you clear-coat it, if so did you wet sand that at all? Thanks.
UNIVERSITY OF ILLINOIS CLASS of 2011 - MECHANICAL ENGINEERING
2001 Z71 Silverado, 5.3L V8, Ext. Cab
Originally Posted by 96extcab
So were you born this way, or was there an accident that causes you to just vomit out dumb things?
DMANbluesfreak is offline
Old 11-05-2009, 12:15 PM   #7
hippies hate deathmetal!
There is only two nuts holding it on the back...why not remove so you can paint the edges?
Looks good tho.
Thnx 9chevy4
Originally Posted by 1989K1500
And if he didnt spaz on you while you where balls deep in his daughter he probably wont flip on you at all.
Blaze5509 is offline
Old 11-05-2009, 12:16 PM   #8
Captain Crunch
c4justin's Avatar
When i paint mine... I just unbolt them and lay them on a table. I use cheap black rattle can at walmart and go to town. I do wash and dry the emblem before hand and then hit it with some sand paper to rough it up a little bit.
c4justin is offline
Old 11-05-2009, 12:46 PM   #9
High on Altitude
North44's Avatar
Looks good! I did this to my Cavalier. The bow tie was a peel and stick. I coated both sides (it was transparent with an ugly gold piece of foil behind it that I threw out) with black paint, and used some PL Nail to glue it back on.
Sold the car, but I still see it around every once in a while and the bowtie is still holdin' up!
North44 is offline
Old 11-05-2009, 01:10 PM   #10
I Will ReDefine OverKill!
when i did mine i used 220 grit sand paper to rough it up a little and used plastic spray paint.
i think i did 4 light coats with no wet sanding.
its holding up awesome
Originally Posted by 90Z71Stepside View Post
You should lift that truck. then you can cross over the grass between the freeway, cut across peoples lawns, drive over sidewalks, take jumps, bush honkin I will say it again bush honkin and run out of gas with the ladies out in the woods.
BigChevy17 is offline
Old 11-05-2009, 01:25 PM   #11
FastBlak's Avatar
Looks good, suprised you didnt undo the 2 10mm bolts and just take it out. Other than that looks great!
FastBlak is offline
Old 11-05-2009, 02:20 PM   #12
Tweaks's Avatar
Don't put too much effort and thought into this as it's just a small item in the grill and how it turns out isn't as crucial as say a bumper or something larger scale like that.
If you remove your grill, you can get the emblem itself out and then you don't need to mask the grill off with college ruled paper like the OP did. You can either scuff the plastic finish with sandpaper or if you have a scotch pad, you can just use that. Once it's looking thoroughly scuffed, you can spray it with three light coats to ensure good coverage. Let it tack up for about 5 minutes between coats. If you have clear, let the final color coat dry until it is tacky and then just apply the clear coats the way you did the color and you're done. Let it dry long enough to handle without putting finger prints in the finish and just reassemble the emblem into the grill, put the grill back on and call it good.
That's how I went about coloring mine a GM dark grey metallic. I was a bit quick to apply my clear so it absorbed into the color instead of sitting on top and creating that nice gloss but I still like how it turned out and I know that I can always just remove it and redo it fairly quickly if I feel the need to.
00 RCSB Z71 / ss Spintech exhaust / Z71 Tahoe valance / EBC slotted&drilled brake rotors / Edelbrock headers / Blackbear tune/ 6000k HID low beam and fog lamps / Auto-headlight mod(nice)/ Vette servo
Wish List: E-fans
My allergies to these fans... has returned-Slapshot
Tweaks is offline
Old 11-05-2009, 03:34 PM   #13
Cool, I actually did the paint layers last night. Do i need to do anything to it before clear coating it (since its no longer "tacky")?
Old 11-05-2009, 03:49 PM   #14
twotone 88 stepside
m grasso's Avatar
After a few coats of paint wet sand with 600 grit then wa**** and dry it, then put a few coats of clear, if it isint smooth you can wet sand the claer with 1000 grit.
m grasso is offline
Old 11-05-2009, 08:33 PM   #15
Cool, thanks!
Old 11-05-2009, 08:44 PM   #16
You can just wetsand it with 200 grit and get some gloss black epoxy based paint and go to town, it turned out really nice on mine
97 C1500
MrGoodtime is offline
Old 11-05-2009, 09:11 PM   #17
Well, I'm painting it blue to match my paint so that won't work.
Old 11-05-2009, 09:14 PM   #18
Arnold355's Avatar
take some pics when its done man i want to see it
Old 11-05-2009, 09:20 PM   #19
Oh, I plan on it! A lot of work went into this haha.
Old 11-05-2009, 09:28 PM   #20
Tweaks's Avatar
That will go nicely with the look of your truck. I'm sure you've probably cleared it by now but like others have said you can get away with wet sanding it with all sorts of different grits of sand paper. Clear does a good job of filling in all the imperfections and scuffs from the sanding process so it ought to turn out great no matter what you do. You could just clear it as is but giving it a scuffed surface to adhere to will ensure that it bonds better and looks good for years to come.
Wish List: E-fans
Tweaks is offline
