Old 11-24-2007, 04:58 PM   #181
91chevZ71
hold my beer & watch this
91chevZ71's Avatar
Member ID: 50434
Re: Rear View Mirror
just got done with the new mirror. works great!
Thanks guys
THe compass is actually working right...no calibration necessary
well, I take it back. My compass was AFU until I found this
Still building up to the SAS...
Old 11-25-2007, 06:22 PM   #182
watchmego4it
watchmego4it's Avatar
Member ID: 78544
Old 11-26-2007, 03:14 PM   #183
91chevZ71
91chevZ71's Avatar
Member ID: 50434
Originally Posted by watchmego4it
?? what? WTF
Old 11-26-2007, 03:19 PM   #184
BlackBlazer92
Currently a jeeper
BlackBlazer92's Avatar
Member ID: 48838
??? whats going on???
o sweet mirror i am doing the same thing i hope it works right like yours.
Blazer is sold
new dd- 1999 pontiac grand prix gtp
stock fully loaded
new project. 1989 jeep cherokee 2 door
rear top chop, 35" bfg a/t, 4.0L aw4, d30 d44, 3.5" lift. lots of trimming
Old 11-26-2007, 09:47 PM   #185
91chevZ71
91chevZ71's Avatar
Member ID: 50434
LMAO for some reason...
all those smileys are funny
Old 11-26-2007, 10:22 PM   #186
2wdchevywt
2WD MONSTER
2wdchevywt's Avatar
Member ID: 72902
what number would hartford CT be under. It looks like either 11 or 12 and i don't have the manuel
1992 CHEVY 1500 WT 2WD 4.3 V6 4.10 GEARS, 31" TIRES, 4" ROUGH COUNTRY SPINDLE LIFT
2004 CHEVY 1500 Z71 5.3 SILVERSTAR ULTRAS IN HIGHS, LOWS, AND FOGS. PREDATOR TUNER, AFE INTAKE, FLOWMASTER 40 SINGLE IN DUALS OUT
06 Yamaha R6
Old 11-27-2007, 01:39 PM   #187
91chevZ71
91chevZ71's Avatar
Member ID: 50434
I'd go with eleven
Old 11-27-2007, 04:29 PM   #188
2wdchevywt
2WD MONSTER
2wdchevywt's Avatar
Member ID: 72902
or i could just put it in cal and drive in circles right?
06 Yamaha R6
Old 11-28-2007, 05:35 PM   #189
91chevZ71
91chevZ71's Avatar
Member ID: 50434
Try it and see
Old 12-01-2007, 02:26 PM   #190
Dubbsy
I think I broke it.
Member ID: 49650
I've got a question about the OEM harness in a NBS (01 tahoe). Is there a plug under the overhead console? One of the diagrams makes it look as so but I'd need to pull the headliner out and I'm trying to avoid that if at all possible. I've apparently got a short somewhere up around the mirror and I want to get it tracked down before I burn the truck up.
2001 Tahoe 4x4
Old 12-08-2007, 10:19 AM   #191
JMH1950
JMH1950's Avatar
Member ID: 78027
I have a similar questing to the one above.
I just picked up a auto dimming compass mirror from the j/y yesterday and was wondering if there is a switched power supply under the head liner in the '92 silverado or would I have to get creative with the wiring?
'92 C1500 Silverado 305 (Patch)
'94 Bonneville SE (Christine)
'66 Piper Cherokee 180 (Tiger's Toy)
Old 12-08-2007, 01:09 PM   #192
BlackBlazer92
Currently a jeeper
Member ID: 48838
i just put my new mirror on and the button that holds it to the windsheild popped off. it has happend before and i just glued it on with this kit from autozone. well this time it came off and took chunks of the windshield with it has this ever happend to anyone
Blazer is sold
stock fully loaded
Old 12-28-2007, 12:33 PM   #193
txgunrunner
Member ID: 43401
i just looked at the back of my rearview which only has the passenger side air bag light and a 9 wire connector. i havent verified if i have the temp sensor but if i do does this sound like all i have to buy a mirror and plug and play? i read the whole thread and read about the 7 wire plug but nothing about the 9 wire. thanks for the help
It is better to die on your feet than live on your knees.
Old 01-04-2008, 10:01 AM   #194
aelancaster
Member ID: 63890
Just put my temp/comp mirror in last night. Was reading temp fine this morning and the compass works well on calibrated. Temp is reading 90-94 degrees and I can assure you that that is way off, it is more like 40 something outside. What should I check?
Old 01-04-2008, 10:21 AM   #195
BlackBlazer92
Currently a jeeper
Member ID: 48838
were did you put the sending unit? it may be reading off if its to close to the motor. i put mine right behind my front bumper light and sometimes if u leave it sit running it will start reading a little bit hot because of the heat from the motor.
Blazer is sold
stock fully loaded
Old 01-04-2008, 02:32 PM   #196
aelancaster
Member ID: 63890
Mine is a 07 classic, the sensor and wiring were already in place.
Old 01-04-2008, 03:28 PM   #197
BlackBlazer92
Currently a jeeper
Member ID: 48838
ooo in that case i cant help ya??? maybe its a bad senson
i read the troubleshooting section on mine and i remeber it saying something on how to fix it if its reading really hot i cant find the book though? did u try un pluging it and trying again?
Blazer is sold
stock fully loaded
Old 01-04-2008, 04:40 PM   #198
aelancaster
Member ID: 63890
Thanks for looking. I did try unplugging and plugging both the mirror and the sensor,no luck. Sometimes it reads correct and sometimes reads really high like 99 degrees. Just wish I knew if it is a bum sensor or the mirror I got off ebay is bad. The compass works perfect.
Andy
Old 01-08-2008, 05:17 AM   #199
aelancaster
Member ID: 63890
Any ideas on how to check the sensor or the mirror? I don't want to just throw money at this problem if I do not have to.
Old 01-08-2008, 05:38 PM   #200
JMH1950
JMH1950's Avatar
Member ID: 78027
The zone map that is in my drivers manual is totally different than this one that is posted above.
http://i184.photobucket.com/albums/x...ssZone_Map.gif
This one I'm zone 3 and on the one in my owners manual I'm zone 9.
However I'm using a mirror that I bought from a J/Y, any way to know which zone map is right, besides driving onto the airport runway compass rose?
HTML code is On
