Old 07-04-2006, 04:56 PM   #121
sanger dude
Member ID: 50550
Re: Rear View Mirror
This is an ACDelco connector kit... still in package...so is the mirror, all are brand new, and I am trying to figure out the wiring for the mirror itself as all the wires are white...not individual colors...this is just on the connector kits themself.
Bill
Old 07-05-2006, 08:48 PM   #122
sanger dude
Member ID: 50550
Anybody??? like I said I have an ACDelco pigtail harness that is supposed to be used to wire the mirror up...it is a 7 pin style...
anyone???
Old 07-06-2006, 06:13 AM   #123
kw2500hd
Member ID: 16635
Did you look above your headliner? Most trucks already have this harness and connector in place. What year is your truck?
Old 07-06-2006, 06:46 AM   #124
sanger dude
Member ID: 50550
Well, that is the problem, I am trying to retro fit this to a MUCH earlier suburban...so there are no wires
Old 07-27-2006, 08:45 AM   #125
AirSchatz
AirSchatz's Avatar
Member ID: 32161
I have a question about the 12 v + power supply connection. Does it need to be connected to a switched supply or a full time supply. Switched with the ignition key or connected to a full time power supply to keep the compass calibrated?
Thanks
1992 Chevy Silverado
Old 07-30-2006, 03:06 PM   #126
CrewCab
Rockin' the back seat!
CrewCab's Avatar
Member ID: 1931
i had a map light mirror in my s10 before i drove 8 2x6's through it and the windsheild...
You know the world is screwed up when the best rapper is white, the best golfer is black, the tallest guy in the NBA is Chinese, the French are accusing the USA of arrogance, and the Germans don't want to go to war.
Old 08-19-2006, 12:10 AM   #127
NIN_Silverado
Goddamn this Noise
NIN_Silverado's Avatar
Member ID: 53376
Orignally posted by: kw2500hd
I want to change my mirror to one of those comp/autodim/temp mirrors, i took off my overhead console and found that harness your talking about. So does that mean that i can just use that harness and plug it in to the new mirror. Wondering if the temperature feature will work? i dont know if there is a temp sensor installed behind my grille. What do you think...i have a 2000 silverado.
*almost forgot the plug attached to the harness is a 7 pin plug, but theres only 5 wires connected to it. the colors of the wires are GRN/WHITE, BLK/WHITE, then solid BLK, GRN, and RED. Thanks
Old 08-19-2006, 06:12 AM   #128
kw2500hd
Member ID: 16635
Take a look thru your grill, if you have the temp sensor already in place it should be about 1 ft from the driver's side headlight, mounted on a horizontal brace in front of the radiator. The connector on it is blue and green. If you don't have the sensor, you may still have the connector, it might be tied off somewhere. My 2001 2500HD did not have the sensor or connector.
Temp sensor--GM PART # 15047946
Connector (special plug for sensor w/10" of wire)--GM PART # 15306078
Both are available from GM Parts Direct.
http://www.gmpartsdirect.com/
Other than that, all you need is the mirror. I got mine off ebay. Make sure you get one WITHOUT the Onstar. That one has a much bigger connector on the mirror. 5 wires are ok, I think mine only had 5 wires. I believe the other 2 wires are for driver door mirror dimming.
Let me know if you have any more questions, as I did this exact same mod to my truck.
Old 08-22-2006, 09:50 AM   #129
SoCalChris
Member ID: 53095
I'm trying to do this to my 06 W/T. I've got the mirror installed. The compass works, and the temp shows OC.
From what I've read, the wires for the temperatur probe terminate somewhere around the fusebox under the hood, but I can't find them anywhere.
Does anyone know where they are at?
Old 09-03-2006, 08:26 AM   #130
hberry
Member ID: 54189
Hi all -
N00B here, I just purchased an 02 Silvy 1500 with the standard boring mirror and I found this thread. Do you think its likely the harness is there on an LS model of an 02 Silvy? I'm not that great at taking stuff apart without brearking it on the way back together.
Mike
Old 09-03-2006, 09:55 AM   #131
Kaos_Dad
Kaos_Dad's Avatar
Member ID: 45432
Try ebay motors
I'd rather be lucky than good any day....... But im neither...
Old 09-03-2006, 11:09 AM   #132
78C-10SWB
Member ID: 2835
I have a 00 Silverado and when I lowered the small overhead console, the harness was there. Plugged it in and after the compass calibrated itself, it works. Just need to find the temp sensor wire to connect that up.
Originally Posted by hberry
Hi all -
Mike
Old 09-03-2006, 11:13 AM   #133
kw2500hd
Member ID: 16635
Hi all -
Mike
To see if you have the harness, (I'll bet you do.), you have to take out the overhead console. To do this, all you do is remove the one screw at the front edge of the console, then slide the console forward a couple of inches. Carefully lower the console a few inches and unplug the lights. Feel around above the headliner thru the hole exposed where the console was. You should find a multi wire harness with a plug on it. That's the one.
Here are the #s if you need them. These are for the temp sensor located behind the grill.
Old 09-06-2006, 09:34 AM   #134
hberry
Member ID: 54189
Thank you for the great info. I will take a look at it this weekend to see if I have it.
Old 09-06-2006, 03:18 PM   #135
AirSchatz
AirSchatz's Avatar
Member ID: 32161
You can get the connector w/o wiring and wire it yourself much cheaper. At Scoggin ****ey, the connector w/wire $50 or $60. The wires were all white, no color matching. The connector w/o wire, $8. Got the metal inserts at a electronics supply for a dime each, you will need 5. and about 5' of 18 gauge wire.
Old 10-07-2006, 04:18 PM   #136
joealphin
joealphin's Avatar
Member ID: 49438
thanks for everyones help .i found the sensor with the plug on e-bay . never could find the wiring under the hood . i just ran 2 new wires up to the mirror and spliced them in works perfectly .
Old 10-07-2006, 09:27 PM   #137
DirkDiggler
Member ID: 34362
Any of you guys with new trucks find that the temp sensor was already in place?
Old 10-08-2006, 05:15 AM   #138
kw2500hd
Member ID: 16635
My 2001 2500HD is an LS and it did not have the sensor already installed. In fact, I had to run wires from the connector by the fuse box down to the front of the radiator for the sensor. It seems to be a crap shoot on whether the sensor is installed or not.
Old 10-09-2006, 10:04 PM   #139
chevyguy78
BigGreenZ
chevyguy78's Avatar
Member ID: 46504
ok if you dont mind spending the money CIPA makes a rear view mirror that will fit just about anything. i got one for mine it is cake to hook up i might even know a guy who has one in his 67 chev pu and he was talking about selling it but i have to ask any way i think the mirror retails for around 350 maybe less but it has auto dim map lights compass and temp it is accurate with in 3 degrees i love mine when the temp gets around 37 degrees it say ice on the desplay but if you are interested you may have to pay shipping but i can find out if he wants to sell it so just let me know
Old 11-03-2006, 10:42 AM   #140
Terry
Member ID: 57422
Exclamation Re: Rear View Mirror
Hoping that others are as blessed as I am.....I bought a 2006 GMC Crew Cab that came with the standard day/night mirror. The power pin looked fully wired and the only thing powered on the standard mirror is the passenger side airbag light. I bought an electrochromatic mirror on EBay with compass and temperature (out of an '04 Sierra). Lo and behold, the thing works, plug and play! I had to calibrate the compass (easy instructions in the owners manual) but the truck was already equipped with a temp sensor in the grill. One screw tightened, one plug inserted, and I had a fully functioning mirror for less than 50 bucks. Good luck!
HTML code is On
