Old 02-17-2007, 10:41 PM   #1
Ext cab rear window latch broke
i broke the rear push out window latch on my truck today because I AM DUMB. at around 70mph you can here the wind through that window. so i thought i could adjust it and fix the problem. with out realizing the peice i was going to mess with was plastic i grabbed some pliers and started tweaking it. it didn't take long before it broke. anyways there is my story and i need some help. i searched on here and didn't find anything for this problem. so can anyone help me with websites or even a local junk yard in fort walton beach, florida that will have parts like this. any help would be great. thanks.
04bluezee is offline
Old 02-17-2007, 10:46 PM   #2
Re: Ext cab rear window latch broke
You broke the piece thats part of the frame?
My Truck
Nick is offline
Old 02-18-2007, 09:38 AM   #3
it was the peice that the latch pivots on, the part that is connected to the door. here is a picture of what's broke.
http://i45.photobucket.com/albums/f5...5/108_0162.jpg
Old 02-18-2007, 11:53 AM   #4
I did the same thing on my '99. I glued the window shut.
My Truck
Nick is offline
Old 02-19-2007, 10:07 AM   #5
well i still want to use that window. but gluing the window would fix that problem. do you know anybody that you could order that peice from?
Old 02-20-2007, 02:05 AM   #6
under the knife since 95
LOWGREEN1's Avatar
Yes you can buy just that piece. You might try www.LMCtruck.com or www.Ckresto.com I used to have a GM site that had all that stuff on there pretty cheap but I have since lost it. EDIT: did a little digging and here's the site. http://www.newgmpartsusa.com/
LOWGREEN1 is offline
Old 02-20-2007, 05:14 PM   #7
If I remember correctly, that piece is molded into the window frame. That's why I just glued it shut.
My Truck
Nick is offline
Old 02-20-2007, 05:33 PM   #8
yeah your right that is a part of the window frame if im seeing it right from the pic .i think you would have to buy a new window frame .
Iceberg is offline
Old 02-20-2007, 06:04 PM   #9
Saved by Grace
yz250roost's Avatar
I just took and wrapped a rubber band around mine
99 GMC Sierra,5.3L,Black Bear Tune, Brute Force Intake, 4.10's, 6" Uniball lift, B&M Trans cooler, Escalade Gauges ScanGaugeII from www.3n1autocomputer.com
yz250roost is offline
Old 02-21-2007, 05:45 PM   #10
the peice that broke is the peice that is connected to the door not the window. the latch part that looks like a C, clips on and pivots on to the peice that broke. all i need is the peice that connects to the door.
Old 02-21-2007, 06:28 PM   #11
The only thing connected to the door is the frame.
My Truck
Nick is offline
Old 02-21-2007, 07:57 PM   #12
Bowtie Junkie!
82ndCowboy's Avatar
I went to Chevy and tried to get new latches because Mine are loose, they won't hold the window closed tight and the damn thing rattles over rough roads. The Dealer looked and the latch is a non service item. Meaning you have to buy the whole window frame. So searching junk yards is probably going to be your best bet.
Take Care and Have Fun!
99 Silverado ECSB LS Z71
Vortec 5.3L, Stock for now.
VMOA#4639 - 06 Yamaha Vmax
MWO#1596 - Monsters In The Morning RealRadio 104.1
Patriot Guard Rider
www.myspace.com/82ndcowboy
82ndCowboy is offline
Old 02-21-2007, 08:38 PM   #13
Here's a fix for your wind noise:
http://www.fullsizechevy.com/forums/...d.php?t=194998
My Truck
Nick is offline
Old 02-21-2007, 10:00 PM   #14
you are correct. when i first broke the frame on the door i, for some reasone, thought it was just a smaller peice that i could un-bolt and change out. WRONG!!! so what i did is JB weld the broken peice back on and then if that works i will do that screw method in the thread that nick posted in the last post to tighten the window.
Old 02-21-2007, 10:30 PM   #15
I just sealed mine off and bought a new truck.
My Truck
Nick is offline
Old 02-21-2007, 11:14 PM   #16
Bowtie Junkie!
82ndCowboy's Avatar
Man that screw fix is sweet. I'm all over it tomorrow!
Patriot Guard Rider
Old 02-22-2007, 05:54 PM   #17
YEAH BABY IT WORKED! i put jb weld last night and let it dry all night and day. i just hooked the latch to the frame peice that broke and it works like a champ! now i just have to see how long it will hold up.
Old 04-14-2007, 05:29 PM   #18
Cool Re: Ext cab rear window latch broke
Wish I had seen this about a year ago. My glass shattered going down the road one day. So I goes to the junkyard and get another one but it won't seal up tight. So I goes to the local glass/body shop to get the frame replaced. Well, he buggers up the paint on the outside while he replaces the frame. They had to repaint the back of the cab. And all that could have been fixed http://www.fullsizechevy.com/forums/...ilies/twak.gif
with 2 screws.
Mr milo73
mrmilo73 is offline
HTML code is On
