Re: gauges
There is a good write up on this in the Tech Articles section. It takes a bit of soldering, as you will need to cut off your gauge connnector and solder in a '92-'94 one as well a a DRAC. But it is well worth it as you will not only get a better looking dash with tach, but you will also get the added benefit of being able to recalibrate the speedo for gear/tire changes.
Buffalo
'90 Chev 3/4 ton 4wd, work-daily driver first, toy second
