Old 02-10-2008, 10:45 PM   #1
03 heated seats in a 99
I replaced my cloth seats with some leather from an 03. I had to change the plugs to get them to work, but the 8-way and lumbar works fine. I did this in the summer, not worrying about how cold leather is in the winter.
It was -20 the other day and although the leather is comfortable, sitting on frozen slabs of cowskin is not. Is there a way to hookup the heat on these seats?
I'm trying to use an aftermarket switch that I can run 12v Switched through, and only need the heat to come on when I hit the switch. Is there a wire that I can hook to, that will bypass the seat control module?
kingpimpin is offline
Old 06-27-2009, 05:09 PM   #2
Supporting Member
Jetway's Avatar
Re: 03 heated seats in a 99
Bump. I'm looking for exactly the same information.
It could be worse...
Jetway is offline
Old 11-06-2009, 06:42 PM   #3
Supporting Member
Jetway's Avatar
TTT. Come on, surely someone has an idea!
Jetway is offline
Old 11-06-2009, 06:45 PM   #4
High on Altitude
North44's Avatar
I'm interested in this as well, but for a '97. Anyone?
North44 is offline
Old 11-07-2009, 03:43 PM   #5
wardlws's Avatar
I believe the '03-'06 seat heaters turn on and off through a command sent on the bus wire. You might be able to get them working by directly wiring the '03-'06 seat heat switches to the seats. I'm sure someone can tell you which wire it is.
wardlws is offline
Old 11-08-2009, 10:57 AM   #6
Bump for installation pictures.
white-out is offline
Old 11-08-2009, 09:07 PM   #7
Supporting Member
Jetway's Avatar
bump
Jetway is offline
Old 11-08-2009, 09:20 PM   #8
....used to have a 2 door
99-2door's Avatar
You can't directly wire them, because the door BCM translates the signal from the switches to serial and transmits to the seat module. You could bypass the seat module and rig up your own switches though.
2001 C3 6.0 AWD, 3/4 drop, DDU grille, Volant intake, flowmaster exhaust, pulleys, 05 e-fans, shaved tailgate handle, rollpan...tuned by ME.
2003 Tahoe Z71 5.3L, Silverado clip
1995 K3500 SRW..L31, 4L80e, 14bff
99-2door is offline
Old 11-09-2009, 08:46 AM   #9
Can I help you?
ksukats57's Avatar
Right. Everything is controlled by the BCM, and since the 03 is data it might be harder but not sure on that one.
Regardless you should wire them with their own switches at the seat. The 97 will def. need to be wired at the seat because GMT-400 didn't have BCM's.
2001 k1500HD Sierra ccsb SLT, Lq4, 4l80e, 14 bolt SF, dual Flows, BlackBear tune
67 C10,283v8, all original with 86000 miles!
ksukats57 is offline
HTML code is On
