Old 06-25-2008, 01:01 PM   #1
ProPack
Member ID: 82631
Talking Dash Blower Controls out of whack
No matter where I turn the directional fan switch to (defrost, feet, anywhere in between) air still blows out of the dash vents hard. It does not matter if I have recirculation on or off. Is there a separate damper for the dash vents as opposed to the others?
Old 07-01-2008, 12:38 PM   #2
Hicks-MofG
Member ID: 66342
Re: Dash Blower Controls out of whack
sounds like your flaps or what ever that's called under the center console are jammed or the motor is dead.
What year is it?
1997 K1500 305 v8 4L60E
CFM tech Throttle Body 75mm, Volant Intake
MSD Coil, MSD Wires, E3 Plugs
Shift Kit, Vett servo
Flowmaster Super 44 3" pipe
E-Fan, March Under drive pulleys
Wait4Me - 93 Octane
http://prosilversystems.com
Old 07-02-2008, 07:56 AM   #3
ProPack
Member ID: 82631
The truck is a 1997.
Old 07-07-2008, 09:05 PM   #4
99Z5.3
The Midnight Rider
99Z5.3's Avatar
Member ID: 83436
I think you have a blend door stuck open. More than likely it is the one under the dash.
99', ECSB Z71, 5.3, 31" Cooper Discoverer A/Ts, K&N FIPK, and a little something here and there.
Old 07-09-2008, 06:48 PM   #5
bradenn
bradenn's Avatar
Member ID: 69818
I had the same problem in my '89 except the air would ONLY blow out the foot area. So I took the dash apart and pulled the heater controls out, cleaned them up, put a small amount of white lithium grease on all the pivots, and reinstalled it. I haven't had a problem since.
89 RCSB C1500, 4.3L, 5sp, TB spacer, K&N, DJM 4/6 drop [2" coils, 2" spindle, 6" flip kit], Leer 100XL
To come: 20" Iroc replicas, Line-X inner fenders and box, engine swap, SilverStars
Looking for: Interior parts, please PM/email me if you have anything!
Old 07-09-2008, 07:28 PM   #6
tim k
tim k's Avatar
Member ID: 84862
I reciently had to replace the ac climate control unit in my 97 the ac blew through the floor only but every thing else worked if the dampers dont fix the problem then you may check that it seems like it is common in these trucks
HTML code is On
