Old 06-26-2008, 12:29 PM   #1
92 sierra slx
Hard times Kustoms
92 sierra slx's Avatar
Status: Online
Member ID: 69727
obs glass armrests
can i make all new glass ones by molding these ones in tape or aluminum foil then laying down my matt or should i just use some mdf and fleece then glass it ??? this would be my first time glassing anything
R.I.P my son€:ayden james woodbury
6-16-08-7-30-08
your time on earth was few and i'll be missing you
*SIGNATURE REMOVED FOR BEING OVER SIZE LIMIT*
Old 06-26-2008, 03:30 PM   #2
hca
hca's Avatar
Member ID: 8360
Re: obs glass armrests
you would get better results using gelcoat to keep the texture. Here is how I would go about it:
-wax the armrest pads with Partall Paste (release wax product)
-Brush on a couple coats of PVA (release film, air dries)
-Then spray or even brush on a couple layers of gelcoat.
-When gelcoat is fully cured, do a few layers of fiberglass.
-Pop the armrest out, trim your mold, and repeat the steps again and when done you will have a perfect gelcoated mold.
http://www.partall.com/part.htm
It is alot easier than it seems. Gelcoat requires same MEKP hardener as the resin. Both the PVA and wax you can get from Partall. Its just a matter of finding a place that carries them.
check this out:
http://youtube.com/watch?v=62AGalE5P6g
HTML code is On
