Old 07-08-2008, 10:37 AM   #1
jfendley
DreamWeaver
Member ID: 92168
A/C Recycle Door Motor Knocking
I have a 1994 K1500 Extra Cab Silverado. When turning ignition key on/off their is a knocking coming from the motor that moves the A/C Recycle door/flap under/behind the blower. I removed the blower motor to have a better view of the Recycle door/flap to see what was going on with this knocking. Seems that when the Recycle door/flap reaches the either the full open or closed positions the motor that moves it continues to cycle to move it in the closed/open position. This continues with a knocking sound for up to 20 seconds. At this point it does stop knocking and doesn't have any adverse affect on the HVAC operation. However, this knocking of the actuator motor has become very nerve racking and I'd like to get this actuator motor replaced before the whole thing goes kaput. Anyone know what this actuator motor that opens/closes the Recycle door/flap's correct part name/# is? Any information/assistance on it's easy removal installation would also be appreciated.
Thanks in advance!! (This is my first post)
Old 07-08-2008, 10:58 AM   #2
tatoodkelt
miss you Rachael
tatoodkelt's Avatar
Member ID: 60291
Re: A/C Recycle Door Motor Knocking
First of all, welcome to the site! Your not that far from me.
My 94 Silverado is doing the same thing. I've been meaning to take care of it just havent gotten around to it yet. Too many projects. I would be interested in the part # also.
70 Chevelle-94 RCSB-95 2 dr Tahoe-96 4 dr Tahoe for parts
Originally Posted by stepsidebowtie
Jason, You have got to be one of the biggest deal finding SOB's on the planet.....That or you are just REALLY lucky. I have yet to draw a concrete conclusion on this.
Old 07-10-2008, 10:09 AM   #3
cordatta
Designated Smart Ass
cordatta's Avatar
Member ID: 379
there was a post about this some time ago that i found when mine did it. turn the ign. on but dont start the truck and then unplug the connector at the motor actuator. the motor itself needs to be replaced but you will have to pull the ac to do it.
Old 07-10-2008, 10:25 AM   #4
Jcagle
Member ID: 92273
Its is called a a/c actuator. There 45.00 at Advance auto. I had to replace one on my 93.
93 Chevy siverado 2wd
5sp TBI 5.7
jet chip/K&N/Flowmasters
Old 07-10-2008, 10:28 AM   #5
tatoodkelt
miss you Rachael
tatoodkelt's Avatar
Member ID: 60291
How much of the A/C stuff do you have to take off? Is it a quick project?
Old 07-10-2008, 11:05 AM   #6
cordatta
cordatta's Avatar
Member ID: 379
the recirc door is the one between the firewall and the ac. my guess is that you will have to remove the under dash ac unit. however, i have not tried this specifically, i am waiting to do it once i have the steering column wiring figured out to perform the dash swap on mine.
Old 07-10-2008, 11:11 AM   #7
tatoodkelt
miss you Rachael
tatoodkelt's Avatar
Member ID: 60291
Well, looks like there is only one way to find out! I'll try and ge tto it over the weekend and let you guys know.
Old 07-11-2008, 07:57 PM   #8
Peevee
Member ID: 48660
i got the same problem with my truck so i'm looking forward to the solution here
Old 07-12-2008, 03:03 AM   #9
dave89iroc
dave89iroc's Avatar
Member ID: 73893
just unplug the actuator for now, put it to either outside or recirc, then unplug it
1994 Z71 SCLB 355, Dart Heads, 10.5:1 CR, PM rods, CC XR270HR, CC Pro-Mag RRs, RPM Air-Gap , 4 barrel TBI, 7 qt. oil pan, Headman long tubes , not finished yet
Old 07-12-2008, 08:04 AM   #10
Peevee
Member ID: 48660
Do I have to remove the dash to unplug the actuator?
Old 07-13-2008, 10:07 AM   #11
cordatta
cordatta's Avatar
Member ID: 379
no you can lay on the pass side floorboard and with a small flat screwdriver unplug the connector.
HTML code is On
