Old 07-11-2008, 04:09 PM   #1
buggybluescom
Member ID: 42013
92 manual windows to power conversion added note
I see its posted in a few threads well I did the conversion today well till it started raining. I learned almost all from this site so thanks for the help. what I did find is after removing the harness from a 94 and I just unbolted inner doors completely and swapped much easier no rivets to drill out and fit the same. I wanted to note that nothing works until both sides are hooked up but also needed the relays small squares from the fuse box to power up the windows and locks in my 92 cheyenne w/t. also you will have to drill a hole thru the door pillar as there are none on my model truck. other than that what everyone else has already stated I'll try to get some pics of the squares in the fuse block.
everything cost me just over 100 and is as easy as everyone on the site said it would be. thanks for a great site its been very helpful in making my truck what it is.
HTML code is On
