Old 07-15-2008, 10:10 PM   #1
sktw8
sktw8's Avatar
Member ID: 52193
99-02 Where to get interior piece???
On the 99-02 there is a part of the console that holds the cd deck and a storge compartment. I have seen that same spot that had a blank plate there. Has anyone else seen that and where could I get it?
Jack
2000 Z71 5.3L Painted Bowtie, Straight Pipes with 5" tips, two Kicker CompVR subs with a Profile AP1200 Amp.
Exhaust Sound Clip http://fullsizechevy.com/forums/show...90#post2447390
Old 07-24-2008, 10:09 AM   #2
guumbah
guumbah's Avatar
Member ID: 53669
Re: 99-02 Where to get interior piece???
Do you still have the CD or tape player that was there? They are the same size as a standard half-height computer bay. What I did was go to Micro Center and pick up a utility drawer meant for a computer that had a front that looked good. Then I removed the bottom part of the tape player (it's a U-shaped sleeve) with the rails attached that snap in to the mount on the console. The drawer then mounted right into it (after bending a tab or two out of the way) and the whole thing snaps into the existing place. Put the trim back on and it's all done. No more hole. The little drawer does not open, since the hole int he trim is smaller, but that is not what I was trying to get anyway.
2002 5.3l - Quadrasteer
FYI
lose (lüz): v - to suffer deprivation of : part with especially in an unforeseen or accidental manner
loose (lüs): adj - not rigidly fastened or securely attached
HTML code is On
