#1 |
89 chevyreddy
89' interior
hey guys can a 1989 interior can be change into a 1997 interior? all i want is the door panels would they fit fine or does fabrication needs to be inbolved? thanx gys
89 chevyreddy
#2 |
Hates wating
Status:
Online
Member ID: 75312
Re: 89' interior
From what I've read about doing this to my 89 you would need to replace the inner metal piece on the door itself to work with the 95+ door panels.
04 Silverado 1500 Z71 5.3, 3 BL,Truxedo,Westin Bull Bar,KC Slim lights, MTZ's Eagle's.
![]() 1989 Scottsdale 2500 Rockin a new Drivetrain
#3 | |
Administrator
Status:
Online
Member ID: 26
Re: 89' interior
#4 |
89 chevyreddy
Re: 89' interior
newbie here what inner metal piece should i replace?
89 chevyreddy
#5 | |
Homesick NBer
Member ID: 31582
Location: New Brunswick, Canada(working in Edmonton, AB)
Re: 89' interior
inner door panel, window regulator is rivited to it as well as the door handle. you need the regulator and door handle setup with rods, with the right manual/power door panel of whatever color for this to work. and the 95 up panels have the holes for speakers. then there is the problem of the door panel not matching the dash, and the little door jamb button not hitting the right pad on the panel for the buzzer/dome light to shut off when the door is closed. door shells are identical, so they bolt in just fine. the 95+ panels have a small piece covering the mirror bolt access, while the 88-94 panels its all in one.
1997 GMC Sierra 4x4 4.3L 4L60E KOSS CD player,16mpg,3.73 gears z71 skid plates 89 W/T Grille, fender flares coming.
![]() GM trained 2nd year apprentice at a Chev Dealer Last edited by kenman1717 : 07-26-2008 at 06:17 PM. |
#6 | |
Hates wating
Status:
Online
Member ID: 75312
Re: 89' interior
That part about the 88-94 panels sucks.
#7 | |
Homesick NBer
Member ID: 31582
Re: 89' interior
you must mean the fact you have to pull the entire door panel to take the mirror off, whereas if you have basically a 95 up to 08 all you need to do is pull the little tringle plastic cover over teh 3 bolts. which is a better steup in my opinion anyway.
![]() GM trained 2nd year apprentice at a Chev Dealer |
| Advertisements |
| Thread Tools | |
| Display Modes | |
