07-02-2009, 12:14 AM
Supporting Member
The **** ding noise
i dont know if it is just me or what. The dinging noise for when you seat belt is off or your lights or on seems to have gotten louder, and really annoying. Does this get louder? Or am i just imaging it? Can it be fixed if this thing does happen
thank you xZoomerZx
07-02-2009, 12:17 AM
#2
hit the loud skinny pedal
Re: The **** ding noise
my dads 04 tahoe does that and its unbearable. you cant even hear yourself speak over it.
correct me if im wrong but i think a custom tune can get rid of it??
My name be Alex  This is what i drive
01 Z71- 5.3, leveled out, 33's, loud, 4.56's
90 Burban- Carbed 350, SM465, ~13" of lift, no blocks, d60 on the wayy
07-02-2009, 12:26 AM
#3
Ill cut you...
I dont know about the new trucks but on my 95, I just pulled the module from under the dash and it quit.
01SilvyZ71, Im not far from Concord. PM me if you want to get a mini-meet going sometime.
07-02-2009, 12:30 AM
#4
Soap, Ballot, Ammo
Try this -
Condition/Concern:
A customer might comment that the audible chimes (headlight,door,key) are too loud and they wish to have the chime volume lowered. Currently there is no procedure in SI-2000 to adjust the volume of the Chime.
Recommendation/Instructions:
Chime Level Adjustment:
The radio is used to adjust the vehicle's chime level. To change the volume level of the chime, press and hold push-button 6 with the ignition on and the radio power off. The volume level will change from the normal level to loud, and LOUD will appear on the radio display. To change back to the default or normal setting, press and hold push-button 6 again. The volume level will change from the loud level to normal, and NORMAL will appear on the radio display.
Note: Each time the chime volume is changed, three chimes will sound to indicate the new volume selected.
If I have made you a sig, copy it your photo account.
07-02-2009, 12:38 AM
#5
good work zoomer i remember my dad tellin me about that but we bought is used and it had an aftermarket head unit on it so we couldnt change it.
07-02-2009, 12:44 AM
#6
Soap, Ballot, Ammo
Aftermarket radios dont support the chime function by themselves, it requires a special harness, and some of those have a volume control on them. Pull the radio out and see if his harness has this control, its probably maxed out.
07-02-2009, 08:50 AM
#7
There's a simple fix for the seat belt chime. Buckle the seat belt. It seems to work every darn time for me!
I am neither Republican or Democrat. Liberal or Conservative. Don't try to label me.
Originally Posted by james_8997
it says in the book it came in...fuel tank cap. 22 gallons
Originally Posted by TexMax
You're dad's truck came in a book...?
Originally Posted by Mark13
If it wasn't for the idiots the rest of us wouldn't look so good.
07-02-2009, 09:27 AM
#8
02GMCtruck
Location: Albion, Wa: from Pullman, Wa: from Edgewood, Wa
88-98 trucks you can either remove or modify the chime module. It's the black box under the dash next to the power distribution block.
99-02 the chime is in the BCM. I haven't messed with mine.
03-06 is integrated into the stereo & BCM. I haven't messed with this one either
07+ You can disable the seatbelt light and chime bu unplugging the 2-wire connector on the right side of the drivers seat. It goes to the seatbelt and when unplugged, the truck things the belt is buckled, thus eliminating the chime/light.
Last 3 Stepsides
79 Chevy C10, RCSS/5.0L/TH350/10, 86k. 4/6 drop.
88 GMC K1500, RCSS/5.7L/700R4/NP241/D44/14SF G80, 176k. 9" SAS w/ 35s
02 GMC K1500, RCSS/4.8L/4L60E/NP261/IFS/10, 20k. Sierra HT package: 1 of 234 Trucks.
07-02-2009, 09:37 AM
#9
Supporting Member
haha thank you sir.
Ya i do but there are times like just pulling the truck to the back yard or my lights are still on or other things i like having the noise just not as loud...
i put a after market radio in a few months back with that little box thing. i will go out there and check to see if it has a volume control on it. or put my old head unit in to change it.
thanks for all the help ladies and gentleman
thank you xZoomerZx
07-02-2009, 11:43 AM
#10
Ugh!
What about the passenger seat though? The NNBS dings and flashes at you if the passenger isn't buckled up too.
Best way to avoid annoying dinging is to buckle up, and turn the lights off when you turn the truck off!
01 Z71 ECSB, 3" PA, 305/70-16 on AR 10" Atlas SOLD 9/28/09
2010 Ford F-250 Super Duty Lariat
04 Ford Mustang SVT Cobra
07-03-2009, 07:27 AM
#11
Alot of the aftermarket boxes for the chimes do not have a volume control on them and are definitely too loud. What I do for a lot of customers that claim that the chime is too loud is to take a piece of soft foam and zip tie it a round the box so that it covers the speaker opening on it. That usually muffles it enough to make it not so obnoxious.
mine:92 ECSB, 4/6 Static on 22's
the gf's: 02 2500hd eclb (lift and wheels soon)
07-03-2009, 12:59 PM
#12
Supporting Member
well i fixed it. the box like supraloud84 said it has no volume control. so i just took it apart and unplugged the speaker. i sure hope this does not hurt it in the long run.
before anyone says anything again. i do wear my seat belt just gets annoying for anything else
thank you xZoomerZx
07-03-2009, 05:20 PM
#13
I have always unplugged the wires for the driver's seatbelt under the seat.
07-03-2009, 05:29 PM
#14
I taped the holes with electrical tape, and it was better. But, I may fill the holes with silicone next.
1999 Chevy Silverado Z-71, 5.3L, auto, reg. cab, long bed, LS, Indigo Blue, 4.10 gears, locking diff, floor mounted transfer case, Rancho lift, 285/75r16 BFG mud T/A's, AR-23 16x8, 98 silver Z-71 decals, Tahoe grill, XM, keyless door handles, side tint 22%, rear 5%, amber DRL's, ordered new 4/99.
07-04-2009, 12:05 AM
#15
My moms 05 yukon denali does that too.
MAX
03 Sierra denali quadrasteer. 20' Boss 330s 275/55/20 Pirelli Scorpion ATR, true duel flowmaster 40 series exhaust.
Sig by xZoomerZx.
| Thread Tools |
| Display Modes |
Linear Mode
HTML code is On
