11-04-2009, 09:44 PM
My compass is reading WRONG!
I installed a period correct auto-dim mirror/compass rearview. The North and South are correct, The East and West are opposite! WTF?????? anyone have that happen??
Originally Posted by SloNlo350
I was always under the impression that a Throttle Body spacer did about as much good as burning a $100 and sprinkling the ashes on the hood while reciting magical incantations... well apparently I was wrong. Still not gonna buy one though.
11-04-2009, 09:56 PM
#2
-Nick-
Re: My compass is reading WRONG!
Try driving around in circles. Seriously, it might need to be recalibrated
2005 ECSB Silverado 2500HD - K&N, magnaflow, blackbear tune
1985 RCLB C10- soon to be a short bed
11-05-2009, 12:34 PM
#3
High on Altitude
The manual for my truck tells me to drive around in circles at 5MPH.
Just don't get dizzy!
..and this is a serious post believe it or not.
Let me know how it works out, I know mine is about 45 degrees off but I keep forgetting to drive around and look like a tourist.
11-05-2009, 12:52 PM
#4
You can take the manual's instructions literally and drive in circles OR drive around a block once or twice so the compass goes thru one or more 360º rotations.
Then make sure the manetic north zone for your location is reasonably close.
If still no improvement, try someone else's compass because yours likely is malfunctioning.
11-05-2009, 02:42 PM
#5
I pee'd in your drink
right, before trying to calibrate it, you need to program it for the right part of the country.
11-05-2009, 03:05 PM
#6
....used to have a 2 door
yes, you have to set the declination before you do the calibration.
2001 C3 6.0 AWD, 3/4 drop, DDU grille, Volant intake, flowmaster exhaust, pulleys, 05 e-fans, shaved tailgate handle, rollpan...tuned by ME.
2003 Tahoe Z71 5.3L, Silverado clip
1995 K3500 SRW..L31, 4L80e, 14bff
11-05-2009, 03:16 PM
#7
This is my mirror with the switch on the botttom, not buttons. Mine is exaclty like this but mine has a compass. I am not sure how to program it. A "C" was on the display after I had it plugged it in. So I drove in a circle. It is right in all ways except for E and W.....weird.
11-06-2009, 04:33 PM
#8
Supporting Member
you have to pick a 'zone' and enter that.. otherwise the compass can not compensate for true north.
The manual says M is mirror only, C/M is compass and mirror.
Ignition on, switch in c/m position.
Press and hold CAL button for 5 seconds.
Yakima, WA is zone 3.
Hold CAL button until 3 appears in the display.
Release the switch and your compass should be correctly set.
11-06-2009, 06:02 PM
#9
That is the big problem. Where is the Calibration Button? I will look it over. Thanks for the Info!!
11-06-2009, 08:05 PM
#10
Can Not Find Calibrate/rest button!! ugh...
11-06-2009, 08:10 PM
#11
Nevermind....Found it!! Thanks Guys.
11-06-2009, 10:37 PM
#12
Supporting Member
gotta have patience... you in the right zone now?
11-07-2009, 12:03 AM
#13
Yes I selected zone 3.
11-07-2009, 07:25 AM
#14
Supporting Member
does it work correctly now??????
11-08-2009, 12:47 AM
#15
I still have to drive in a circle.....did not drive the truck today.
11-09-2009, 04:53 PM
#16
WELP.....No Workie....I did all things as perscribed. West is still reading East....East is still reading West.....I have tried recalbrating in each zone. 1-15......besides a difference in directing between north and south....
Any solutions?
11-09-2009, 04:54 PM
#17
Forum Leader
The product is either deffective or it is installer error. Which one do you want to believe it is?
11-09-2009, 04:55 PM
#18
I want it to work, dont give two sh**s which it is.
11-09-2009, 05:05 PM
#19
Try the bottom sentence in my other post (#4) because there may be a very good reason why you might have gotten a good price on what appears to be an older model or non-OEM (for GM) mirror.
11-09-2009, 06:59 PM
#20
Forum Leader
Then try returning the product for another one and pay more attention when installing it this time!
| Thread Tools |
| Display Modes |
Linear Mode
HTML code is On
